F-2 Front Leaf Spring Arch
Old Jan 4, 2020 | 09:26 AM
Myers B's Avatar
Myers B
The rear springs on my F-2 look great, lots of arch. However, the fronts are pretty much flat and level. Does anyone know approximately how much arch there should be in the front springs?
Old Jan 4, 2020 | 09:50 AM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Unloaded (no engine and front clip) the front springs will only have a slight arch. If you see in this picture of my F3, the spring has the arch just before the full engine weight is added. Once the engine is in, the spring is nearly flat. And then when the front clip, hood and all the other stuff is added the spring is pretty much fully flat. The springs pictured here went through a local spring shop to get a few leaves replaced, and re-arched.
Hope this helps, Tom
Old Jan 7, 2020 | 03:53 PM
petemcl's Avatar
petemcl
I replaced the springs on my '50 F2 with Dual Flex front and Super Slide rear springs from Posies. POSIES Rods and Customs ? Super Slide Springs ? Street Rod Parts ? Hot Rod Parts ? Truck Parts ? Ford and Chevy Suspensions and Chassis Parts » POSIES Classic Truck Springs
They recommend Bilstein shocks on the front also. You will find the ride and handling much improved. And the truck sits about 2" lower.
