93 Van A/C problem Help
Old Oct 12, 2003 | 11:51 AM
Vandabird's Avatar
Vandabird
I have a 1993 Ford E-150 Leisure Van. I had a front compressor seal leaking and lost my charge. I decided to replace the compressor with a "rebuilt" compressor. After removing all the necessary parts, I flushed the whole system out with over-the-counter A/C flush. After that I removed the rear A/C system and replaced the valve with a 1994 expansion valve (which should be compatible with an R134a system). After putting it back together I moved to the main system. I put a VOV oriface in the front evaporator and 10 oz of oil in the system and then installed new O-Rings. I pulled a vacuum, which held overnight, at 29 inches. The tag on the firewall indicated 4.75 lbs of R-12. I put in 68 ounces of R134a, which should be about 80%. The low side pressure is 55 lbs - high side pressure 195 lbs. Inside car temperature is 91 degrees, outside temperatire if 89 degrees and the discharge temperature coming out of the vents is 65 degrees and doesn't get any colder, even driving down the road. Can anybody help, have any ideas, suggestions?
Old Oct 12, 2003 | 02:36 PM
Vandabird's Avatar
Vandabird
I also put on new accumulator
Old Oct 13, 2003 | 11:02 AM
Vandabird's Avatar
Vandabird
I just checked rear a/c unit outside temp 90 inside van 95 discharge air 71 at idle, is it possible this new compressor is bad (not pumping like it should) I'm lost.
PapaBearYuma
Aug 17, 2016 09:30 AM
benbuilder
31
Jul 2, 2016 11:29 AM
Ira Brown
Apr 2, 2016 10:12 PM
Ira Brown
Apr 2, 2016 10:07 PM
runstang22
2004 - 2008 F150
Aug 8, 2013 07:29 AM
