Sponsored by: Real Truck
Changing Brake Lines
Old Jan 2, 2020 | 01:02 PM
Bruin008's Avatar
Bruin008
I am about to change the brake calipers, rotors and pads on my truck. I am probably going to change the rubber portion of the brake lines with Motorcraft hoses. I am not changing the steel lines as that doesn't seem necessary my case. I cant seem to find a parts schematic that can verify the rockauto part numbers and the description of the part isn't the clearest, but I think I understand. Can somebody verify these parts for me?
1. 5C3Z2282AA (Rear At Rear Axle Housing; 4WD; w/ Single Rear Wheels; Part Time Drive; Flex hose) I take it these are the rear rubber lines and the driver and passenger side are the same hose.
2. 6C3Z2078BA (Front Left; 4WD; Part Time Drive)
3. 6C3Z2078BB (Front Right; 4WD; Part Time Drive)
Also, can somebody provide me with a link to the tech folder. I read on one of my previous threads there is info on brakes in the tech section, but I cant find the 6.0 tech folder.
Old Jan 2, 2020 | 01:04 PM
Bruin008's Avatar
Bruin008
Disregard the link to the tech folder. I was able to find it.
Old Jan 2, 2020 | 01:06 PM
Colorado350's Avatar
Colorado350
You have to go to the 6.0L forum: https://www.ford-trucks.com/forums/forum107/
tech folders at the TOP
