96 explorer question
Old Dec 30, 2019 | 06:29 PM
99rangerdan's Avatar
99rangerdan
I'm sure it is on here but I can't find it. I have a 1996 v8 awd explorer that I swapped into my 2001 sport trac. Had it running and driving and then the trans exploded. What are the donor trans options. I think it is the 4r70w is there a difference in 2wd and 4wd trans any help would be great.
Old Dec 31, 2019 | 12:46 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Donor trans for this era are going to be a crap shoot. If you have time/money/ability to swap a few in to get a working one then maybe it's the right fit for you. I would look for the same year and model vehicle your current transmission came from. Check the build tag on your current one and compare to the potential donors.
Old Dec 31, 2019 | 01:17 PM
99rangerdan
How year specific are the transmission
Old Dec 31, 2019 | 01:24 PM
99rangerdan
I am open to rebuilding one but my case literally blew into multi peices so I need to know what I can use as core at the least any help would be great I did the v8 swap myself I have good back ground and have ability just don't know all the change overs if I could use a 2wd case and my shafts or if it has to be a 4wd case
wantford
Feb 28, 2010 02:38 PM
bronco2454
Sep 8, 2009 08:53 PM
tkloppel
Jan 20, 2005 11:48 PM
