Sponsored by: Real Truck
Hi
Old Dec 28, 2019 | 01:09 PM
Schelly Wohlsdorf's Avatar
Schelly Wohlsdorf
Hi
We just bought a used 2012 F-350, we drove it highway miles only and yesterday our center message says check locking differential. What is this all about?
Old Dec 28, 2019 | 01:16 PM
WWR's Avatar
WWR
Well I'd first inspect all the wiring running into the rear diff, and if nothing appears damaged, loose or unplugged trace the wires to the front of the vehicle
Old Dec 28, 2019 | 07:45 PM
Colorado350's Avatar
Colorado350
Welcome to FTE!
Im assuming you have a switch to lock the diff, did you accidentally press it?
Old Dec 29, 2019 | 09:17 AM
Oredigger's Avatar
Oredigger
On my 12 f150 we had the same issue, we live in salt country and the wires corroded, rendering the locking differential inoperable. Easy harness to replace as it is mostly under the truck and not tucked in too many crevices. I only got the message when trying to engage the locking dif (by pulling your 4wd selector **** out, not sure how it's done if you have floor shifter) you should not regularly be driving it with it locked, you'll destroy your rear end. Hope that helps
Old Dec 29, 2019 | 09:23 AM
WWR's Avatar
WWR
If you're fortunate enough to have a floor shifter like my '11 FX4 XL there's just a button on the dash center stack, between the radio and upfitter switches.
Old Dec 29, 2019 | 09:29 AM
WWR's Avatar
WWR
Also Schelly....just FYI in the future.... consider a more specific thread title.... something like "rear locker - error message" or similar
Thomasf3
May 29, 2024 11:48 PM
drewkeen
Oct 10, 2019 11:26 AM
therigwelder
Nov 26, 2015 10:01 PM
SoupCan™
Jul 7, 2010 08:27 AM
