!968 sway Bar C Bracket
Old Dec 28, 2019 | 12:03 AM
GreyScar's Avatar
GreyScar
Has anybody Tried to use the Spring Seat off of a 99-2007 F250SD in place of a C-Bracket on the I- Beam? Looks like if you put a Little Puck under Nut, and Drill Hole in Radius arm for set Pin'it would Lock right in Place. And Sway Bar Links come in all Shapes and sizes. Seen one and got me Pondering, and would be a Endless Source..............Maybe remove a Coil................
Old Dec 29, 2019 | 02:43 PM
1TonBasecamp's Avatar
1TonBasecamp
Interesting thought. Haven't seen the bracket in question though. Did you happen to snap any pics of it you could share?
Good luck.
Paul
Old Dec 29, 2019 | 06:44 PM
GreyScar's Avatar
GreyScar
Got one Off Epay for $20, gets here from Texas I'll stick it on and see. Looks like a Slam Dunk Though. Looks like it would cause a 1" lift, but I have no trouble cutting a Coil.
Old Jan 3, 2020 | 01:28 AM
GreyScar's Avatar
GreyScar
Put it on, Fits perfect but the Links would have to be to Short, Looked promising though, But a No Go..............If someone is Running a Lift this is the way to go.
whitesaige
Nov 25, 2017 07:05 PM
sontours
Ford Truck Parts for Sale
Jun 10, 2017 06:05 PM
Da_Lariat_Chariot
Apr 27, 2015 10:21 PM
UncleBob75
Oct 13, 2003 12:21 PM
