Zerex G05
Old Dec 27, 2019 | 08:11 PM
shocks24's Avatar
shocks24
Zerex G05
Hi everyone,
So I have read alot on this forum about coolant and it seems there is a vast majority of folks that use Cat Ec1 rated coolant. On that same note from what I've read Zerex G05 is supposed to be the same as Ford gold and doesn't meet The Cat EC-1 rating. So I was surprised to see that according to the bottle it meets or exceeds Cat EC-1 and others.
Have I just been confused all of this time or did Valvoline change the Zerex formula?
Old Dec 28, 2019 | 07:53 AM
F350 1990's Avatar
F350 1990
I run CAT exclusively in my own equipment, but the Zerex product does meet the Ford spec. There are quite a few Powerstrokes out there still running around with green plus additives and I always convert these over to Ford Gold as the CAT products are prohibitively priced and customers would be shocked to see the numbers.
All I'll add is try to maintain a single chemistry in your cooling system - flush with both block plugs out, radiator drain open and push water thru the heater core................if the flush is accomplished with (hard) well water, follow up with two flushings using distilled water. Once "baselined", stay with that chemistry............
Old Dec 28, 2019 | 08:16 AM
SmackDaddy's Avatar
SmackDaddy
Rotella or CAT ELC is all that goes in my truck. Chemistry
Old Dec 28, 2019 | 12:35 PM
Stewart_H's Avatar
Stewart_H
I'm partial to the Chevron Delo ELC chemistry. 10 years or 1 million miles when the extender is used. I hit the 10 year mark in my Excursion a few years back and had to flush and refill.
To the OP, the Zerex G-01 previously did not meet the Cat EC-1 rating. It does now.
Stewart
Old Dec 28, 2019 | 12:43 PM
SmackDaddy's Avatar
SmackDaddy
Stewart
If I could keep the engine off the stand that long it would be very nice!
Old Dec 28, 2019 | 12:56 PM
Stewart_H's Avatar
Stewart_H
The Ex has the 7.3 so there is that....
The 6.0 in my sig is, well, let me just say, it's sitting in my front yard waiting for the engine to be pulled and put on a stand.
Stewart
Old Dec 28, 2019 | 01:02 PM
SmackDaddy's Avatar
SmackDaddy
Doing a full rebuild on mine for the hell of it
smlford
6.7L Power Stroke Diesel
Dec 11, 2019 02:20 PM
gpeade
May 29, 2019 09:51 PM
jeremiah77
Aug 8, 2015 12:51 PM
mmenzies
May 31, 2015 02:08 PM
cajunsuperduty
Jul 10, 2011 03:26 PM
