1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
DIY center console
Old Dec 27, 2019 | 06:32 PM
dclarke74's Avatar
dclarke74
DIY center console
I have a '62 unibody and I am starting a project to build my own center console to fit over the trans hump. Has anyone tried this? Any recommendations? I have been searching for a good USB charging port option and I just cannot find anything I like.
Any thoughts or recommendations appreciated.
Thanks all!
Old Dec 28, 2019 | 11:22 AM
kenny nunez's Avatar
kenny nunez
DIY console
If you have bucket seats then you will have more room. I added a fuse panel with 12volt power.
I made the frame on mine with 1.5” flange angle iron then cut some 1/2” plywood to fit all the outer surfaces and drilled holes then used the correct thread tap threaded the drilled holes. Then used stainless screws to mount the panels. I then cut the holes in the wood where the power points were to go and in my case to mount the B&M Quicksilver shifter. After I was satisfied I then covered the wood with black vinyl padding by stapling on the back side.
WA.Ranger
Feb 5, 2010 08:44 AM
michaelc
Escape & Escape Hybrid
Aug 17, 2006 04:59 PM
