7.3 IDI Long block. Rebuildable core. $150 Delivered
7.3 IDI Complete eng. Spins free, very tired. With ATS turbo $450 DELIVERED
6.9 IDI Complete eng. Runs OK. $200 Delivered
ZF 5 speed trans from 7.3 4x4 with transfer case. Unknown history $350 DELIVERED
ZF 5 speed trans from 7.3D 4x4. Good core, 2nd gear needs sync. $150 DELIVERED
E4OD Auto trans from 7.3 4x4 with transfer case. Worked when parked, unknown mileage. $350 $300
C6 Auto trans from 6.9D. For 4x4. With transfer case. $300 $225 $200
Transfer case from '88 F-250 $100
Several F-250 axle sets. 1980's, 3.55 and 4.10 gears $250/set
Body parts from 93 F-350 SRW 4 door, long box. Some rust $300 for all Picked Up
GONE5.8/351 Fuel inj engine. Complete. Unknown history. $75 GONE
GONE 300 6 cyl. Long block. Tired, but ran. $50 GONE
'81` 400 gasser. Eng is stuck. 2 barrel. $50
4 spd trans from '81 F-350. 2WD (suspect T-18). Door code F. $80
Body panels and cab from 81 standard and 91 Ext cab. Free - you pull
If I am out of line on prices, my feeling won't be hurt if you make an offer.
I'm in NW WY. About 40 miles N of Cody and 80 miles S of Billings. I will be going to The Ozarks in Dec. Normally we take my wife's Toyota at 40 mpg. If need be I can take the truck with some items in the back.
