Removing Radius Arms
Old Dec 21, 2019 | 09:30 AM
Brody Long's Avatar
Brody Long
New member here 👋. Just been creeping around this site without an account for to long. But I am having a problem with all 8 bolts for both drivers side and passenger. I can not get any I mean any of those bolts to move at all. I was almost able to lift the truck off jack stands with a cheater bar. So I was wonder if anyone else has had a problem with these bolts and what were your methods or if you know of a good method to get these suckers off?!
Old Dec 21, 2019 | 10:04 AM
Ozzie H.'s Avatar
Ozzie H.
Perhaps there is some corrosion involved. Could you do better by removing the large nut on the end of the arm instead? The Ford Shop Manual doesn't mention removal of the bracket. It says to remove the large nut on the arm.
Old Dec 21, 2019 | 10:16 AM
Randy Nix's Avatar
Randy Nix
What year? You're lucky to have bolts. A lot of them where Rivets.
I was also luck with bolts but they where a bitch to get off but after some PB blaster and just working as many angles as I could eventually got them all off.
Tried to grind and cut some of them off but that never panned out. I think a couple of the bolts broke off which was a blessing!
If you just remove the Big bolt on the end of the radius arm like Ozzy H said you will also have to pull the front axle forward to get it to come out.
There is some work to go that route. I hate Radius ARMs!
Old Dec 21, 2019 | 10:30 AM
John89's Avatar
John89
Try using some Kroil. I haven't found a nut or bolt it hasn't worked on yet. (Knock on wood)
let em soak for a day or two and hit em again with it. Tap them with a hammer to help loosen things up. Maybe a little heat.
We pulled the axle when we did ours, so we could get a good angle and bite on em.
Old Dec 21, 2019 | 10:31 AM
Shawner1974's Avatar
Shawner1974
When I lifted the suspension on my 76 short bed about 25 yrs ago, I resorted to breaking every one of them off. A piece of pipe and a breaker bar did the trick. When I put the drop radius arm brackets on, I used a bit of anti-sieze on the grade 8 nuts and bolts. Not a fun job by any means, especially if you forget to put wheel chocks on the front tires!
Old Dec 21, 2019 | 12:41 PM
caravaggio2000's Avatar
caravaggio2000
I recently replaced the bushings on my radius arms. I removed the big nut on the end and the bolt going through the front and it came out no problem. I did have just about everything else apart though (like the tie rod ends).
Give all the old hardware a few good soaks with PB blast and allow time between to soak. Also, a bf breaker bar. Mine had a hole for cotter pin (though none in it), make sure yours is out.
vettman
Oct 19, 2011 04:40 PM
Tedybear
Feb 18, 2008 06:31 AM
66gpw
17
Aug 16, 2006 05:35 PM
wjawill
1978 - 1996 Big Bronco
Sep 22, 2005 07:07 AM
Lee Lichterman
Dec 12, 2004 02:05 AM
