Low Fuel Pressure
Old Dec 18, 2019 | 07:34 PM
Flyinstroke's Avatar
Flyinstroke
Low Fuel Pressure
2002 F-350 4x4 Dually 340,000 miles
Having issues with Low fuel pressure. What I have done so far...... I have a new pump on it (same results from both pumps, which are Bosch pumps ). I have the gauge connected on the pre filter port on the fuel bowl. I am only getting 30 PSI. I have already tried using a clean unrestricted fuel source ( i.e. fuel can ) connected directly to the pump. Still can only get 30 - 35 PSI pre filter. Anything else I need to check. And where do I go from here? I have tried searching other threads but solutions are few and far between when people get stuff fixed.
Thanks in advance.
Old Dec 18, 2019 | 07:47 PM
brokestroke's Avatar
brokestroke
Replace the FPR spring?
Old Dec 18, 2019 | 07:50 PM
mike71800b's Avatar
mike71800b
First verify 12v across the pump leads while under load.
Second check there are no obstructions between the pump and fuel bowl.
Old Dec 18, 2019 | 07:56 PM
Walleye Hunter's Avatar
Walleye Hunter
Yep, fuel pressure regulator on the side of the fuel bowl is in the game.
Old Dec 18, 2019 | 08:13 PM
Flyinstroke
I checked the voltage already under a load and it is fine. I will recheck for obstructions and also change the FPR spring tomorrow. Keep the ideas coming. I am having a major brain fart right now.
Old Dec 18, 2019 | 08:21 PM
AllaboutMPG's Avatar
AllaboutMPG
Sure sounds like the fpr is suspect. Could have some internal damage or wear. Might consider a riff raff frx
https://www.riffraffdiesel.com/fuel-rail-crossover-frx/
Old Dec 18, 2019 | 08:24 PM
Flyinstroke
The FPR is making more and more sense. When I was sucking fuel out of a fuel can it sucked a full 1 ½ gallons in really quick. Like less than 2 minutes. If the FPR wasn't working it would be returning more fuel than it is supposed to therefore causing low fuel pressure correct?
Old Dec 18, 2019 | 09:27 PM
timmyboy76's Avatar
timmyboy76
You can install a BB under the spring to raise pressure. If too much, cut a coil then recheck..
Old Dec 18, 2019 | 11:31 PM
mike71800b's Avatar
mike71800b
Thats a lot of flow, inspect the valve and seat area of the fpr.
Old Dec 19, 2019 | 06:51 AM
SkySkiJason's Avatar
SkySkiJason
This is the most common FPR failure and shimming the spring will not help.
If this is your problem, here’s a source for the parts you’ll need.
https://www.dieselorings.com/7-028-f...build-kit.html
You’lll also need the vibraloc sleeve for return line.
Old Dec 19, 2019 | 06:56 AM
Flyinstroke
I am hoping to get it pulled apart on my lunch break today. I will give you guys an update and let you know. Thanks for all the help
Shawn Paris
Aug 2, 2016 10:56 PM
srauner
15
Jul 30, 2010 08:22 AM
DJdemon6696
27
Dec 2, 2007 04:43 PM
Tex311
Bronco II
Jan 23, 2004 10:50 PM
