Info only: Front leaf spring bushing sizes
This is the correct kit if you have stock springs. It does not fit the aftermarket springs that I have (Rough Country 6” lift), it takes smaller bushes than the stock ones.
The diameter of the bushings you need for the front leaf springs from RoughCountry are:
Forward: 37.10mm
Rearward: 35.15mm
Sleeve length: 89.5mm
I haven’t checked if EnergySuspension sells bushes on these sizes. I took the ones I bought to a machine shop to turn them down to the size I needed. Hope it helps.
