I been reading all yall writ about who I be. Ise just a good ole boy what fount this ford thang by axident. I do has a 55 Ford truk tho. I aint been on this here place before and i flat need yalls hep. Sombody writ about my signatur well I copied it frum another person somewheres else.
I am vury sorry . I didden relize that Him was a name. I thought it was a place. I hope he aint mad. I caint spell his last name can I call him by his christian name?
I did thank of my qwestion.
How do ye get that steering box thang at the other end o the steeering wheel off? I fount one in a field but my cuz says I got to take the steeering whel off. It aint bad its that box thang thats bad. He also sed I had to take the rod thang off but iffen i do that wont the gear shifter thang fall off 2
I thought patois was the term they used to describe the look on your face when you see your wife talking to one of your old girlfriends when you made the mistake of taking her to your class reunion.
Jeff
Actually Himmelberg busted him out yesterday. It's Kenny from Jersey. He does his Forum Master nice guy routine with his "Kenny" handle. Then when he's feeling ornery, he takes over peoples FTE ID and does all this other stuff. You know all those smart aleck posts you see from George, RMF, Dick and I? Kenny does almost all of that. He just uses his super FTE powers and there ain't a thing we can do about it.
Kenny (er I mean 55Bubba)
Just blow the steering box thingy off with a torch, you won't be needing it no more after you get a cool Flaming River tilt column.
Last post from me guys, I have to answer his question then I promise I'm outa here.
"Im serius yall how do i get tha steering box off without taking off the steering wheel?
Bubba55"
Here's a tech article I wrote just for you.
1. After loosening the steering box from the frame, slide the entire assembly up until the the steering wheel hits the cab roof and the box hits the floor. Trace around them with chalk.
2. Fire up the torch and cut a hole in the cab roof and floor. Follow the chalk marks from step one.
3. At this time you can pull the entire assembly out through the roof. You'll have some big holes that let rain in but you pull a piece of skirting from your mobile home and make a patch. EZ fix.
4. Now take the torch and cut off the steering box like I told you before. No need to remove the steering wheel at all.
5. Now buy a gay steering column of your choice and you're set. I like the Flaming River myself.
Himmelberg is a mountain in heaven. And my name. Fortunately, we have some keen viewers here to unravel this crafty disguise of our very own moderator. We Jersey boys do not have an accent, do we Kenny?
Thanks to 'fenders... this case is closed.
Best. Himmelberg
Personally I think that it's Earl. But whomever it may be, they can deffinitly read/write correctly and have never been to the south. The phonics is too good for someone who can't really read/write, and the southern "slang" is written wrong.
55bubba, you don't have to take the wheel off to get the box out. All you have to do is take the floor covers off in the cab, disconnect the steering box from the frame and then cut, torch or beat the steering rod off the end of the box then pull the whole thing up into the cab. It worked on my '41, and maybe it'll work on your '56...err...'55.
