Oil pressure sender problem
Old Dec 9, 2019 | 01:30 PM
CanOfBeans's Avatar
CanOfBeans
The engine is a 351M and I'm just about finished rebuilding the thing and now I have yet another problem. It's completely seized into the block. I've scraped around the edge with a screwdriver and can't even see how it was put in. I've hit it with heat, pb blaster and everything else. Anyone ever heard of this before?
I kinda went a little overboard with the vice grips and chewed the thing up. Hopefully I didn't screw myself. but I just wanted to know if anyone else has this problem
I
seen posts on this forum about relocating it next to the fuel pump so I'm thinking that's what I have to do.
Old Dec 9, 2019 | 01:44 PM
bluovl's Avatar
bluovl
I
Cut the thing off flush with a cut off wheel, and then use an easy out. Careful not get any debris in the oil gallery.
Old Dec 9, 2019 | 02:10 PM
dlburch's Avatar
dlburch
how much heat did you apply? I would get it glowing red. a regular pipe wrench might get you a better grip than vice grips...if the pipe is tall enough. You can try in internal pipe wrench (I think they make them small enough). If not, I would try a stud extractor before I cut anything...last resort would be to cut, heat up the remnants until glowing, then try the easy-out.
Old Dec 9, 2019 | 03:27 PM
CanOfBeans's Avatar
CanOfBeans
I only warmed it up with a little propane torch so I didn't put a whole lot into it. Thanks for the recommendations man I'm definitely gonna try those
Old Dec 9, 2019 | 03:33 PM
CanOfBeans's Avatar
CanOfBeans
Yeah hopefully I don't get alot in there
markotheguy
May 15, 2019 07:40 AM
JoeDaf
Mar 3, 2018 10:46 AM
stevorino
57
Jun 16, 2016 08:59 AM
Bite N Hold
Aug 18, 2015 05:20 PM
evam350
Jul 1, 2014 11:04 PM
