Ignition switch
Old Dec 8, 2019 | 11:27 PM
AbusedAmericanRust's Avatar
AbusedAmericanRust
Ignition switch
Hey guys I’m having a fun problem with an ignition switch on my bronco.
When I go to install the switch assembly into the dash, as I tighten the lock ring down, the face of the tumbler wants to spin with the lock ring.
If I install the lock ring with the key in the tumbler I can get the ring to tighten down correctly but the switch sticks in the start position.
I’ve mixed and matched a ignition switch provided by American Autowire, another (oem style) from LMC, a tumbler from LMC and 2 different oem lock rings with the same result
Anyone run ever run into this before? I’ve had a few of these trucks and this is a first for me.
Old Dec 9, 2019 | 01:38 AM
1TonBasecamp's Avatar
1TonBasecamp
Is this a '78/'79 Bronco? Or an Early?
Paul
Old Dec 9, 2019 | 07:56 AM
AbusedAmericanRust
It’s a 1978
Old Dec 9, 2019 | 01:04 PM
1TonBasecamp
Ok, not as familiar with those. I have a '79 but have never had to replace the switch. Yet...
Hopefully someone has some insight for you.
Paul
Old Dec 9, 2019 | 10:03 PM
1977 FlareSide 400's Avatar
1977 FlareSide 400
Lightbulb
Youtube has some good videos on our ignition lock cylinders, maybe you'll spot something or a step you missed?
1973-1979 Ford F-Series and Bronco Ignition Lock Cylinder Removal and Replacement.
Youtube list . . .
https://www.youtube.com/results?sear...Lock+Cylinder+
tgun
Nov 14, 2019 05:47 PM
EglsMntnFab
Feb 11, 2013 04:47 AM
glassell_park
May 14, 2010 12:55 PM
subdude
1978 - 1996 Big Bronco
Nov 10, 2003 08:19 PM
