Extremely Fast Oil Life Countdown
Old Dec 9, 2019 | 08:52 PM
jrwinger's Avatar
jrwinger
Originally Posted by C12H24
The suggestion to filling the oil filter is a long-standing precautionary procedure to get oil to the system as quickly as possible. All you're doing is pouring oil into the filter before you screw it on. It should go without saying that you can do this only when you have a vertical oil filter with the opening at the top. It has never been proven by anyone anywhere that failing to do this actually causes any problem whatsoever. If you don't do it, the engine is running for about five seconds without fully-pressurized oiling. Again, not enough time for anything of consequence to occur.
As to your suggestion on finish filling the system after running it. Not necessary. Put the full fill in.
Got it. Thanks for the clarification!
benwalt
2015 - 2020 F150
21
Feb 24, 2017 07:41 AM
golfmedik
6.4L Power Stroke Diesel
16
Jul 7, 2013 09:03 PM
ruskeigunlover
2009 - 2014 F150
Jul 3, 2013 06:05 AM
wolf189
2004 - 2008 F150
Jan 30, 2011 06:54 PM
Randy777
Dec 10, 2006 07:32 PM
