stroke a 400?
Old Oct 11, 2003 | 02:02 AM
coolmint94's Avatar
coolmint94
stroke a 400?
What is the maximum amount you could stroke a 400?
Old Oct 11, 2003 | 03:37 AM
Brian S's Avatar
Brian S
Max 400 stroke to date is 4.5"
with a very expensive custom made crank. The 10.3" deck height is the same as a 460 but there is slightly less room for cam clearance. The 351C/351M/400/429/460 use the same timing gears but the 429/460s have a longer chain. (+2 links)
-Edited adj timing ques for own topic- Admin
Old Oct 11, 2003 | 06:04 PM
coolmint94's Avatar
coolmint94
so what would be the final cubic inches????
Old Oct 11, 2003 | 10:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
459 cubes at a 4.030 bore, 4.5" stroke.
Old Oct 11, 2003 | 11:17 PM
Brian S's Avatar
Brian S
Cam advancing & Maximum CID
Maximum size depends on the bore. 4.5" stroke with
4.0 bore = 452
4.030 = 459
4.060 = 466
4.185 = 495
http://www.kb-silvolite.com/temp/calc.php
I was in the middle of the variable cam answer but the thread was moved so I'll respond there.
yankeerebel
Feb 9, 2014 05:36 PM
andy 1979
18
Dec 7, 2010 09:44 PM
