1978 - 1996 Big Bronco
gear ratios
Old Oct 10, 2003 | 10:21 PM
BRONCOMAN_1980's Avatar
BRONCOMAN_1980
gear ratios
does anyone know if i can run a dana44 3.50 gears in the front and a ford 9" with 3.55 gears in the rear, will it mess anything up??? i have a 1980 bronco with a 351w 4X4
Old Oct 10, 2003 | 10:27 PM
andym's Avatar
andym
You're a little backwards. The 9" is available with 3.50 gears, and the Dana 44 with 3.54.
That being said, it is within acceptable tolerances. To be safe, I wouldn't drive it much in 4x4 on dry pavement.
Old Oct 10, 2003 | 10:28 PM
hoxiii's Avatar
hoxiii
As a rule of thumb keep the difference between gears to 2% or less. to figure this: divide the smaller gear by the larger gear, multiply that number by 100, and then subtract it from 100.
3.50/3.55=.98591
.98591*100=98.591
100-98.591=1.409% difference. . .
you'll be fine
Old Oct 10, 2003 | 10:32 PM
BRONCOMAN_1980
from what i can read on the tags the rear has 3.50's and the front has 3.50's but i blew the rearend out and someone will sell me a rearend with 3.55's for $50, i just didn't know if it would hurt anything
Old Oct 10, 2003 | 10:37 PM
BRONCOMAN_1980
OH I ALMOST FORGOT THE REAREND IS OUT OF A 2 WHEEL DRIVE PICKUP....
