INSTRUCTIONS: How to remove a SHIFT KIT
Old Oct 10, 2003 | 08:55 PM
SBelk's Avatar
SBelk
Question INSTRUCTIONS: How to remove a SHIFT KIT
Hi Everyone!
I am in need of Instructions for the removal of a shift kit for this truck below....
1994 F150 4x4
V.8 5.0
Trans: E40D
If you know how to and/or know where instructions might be, please send an email to me or just post it below.
Thanks!
Old Oct 11, 2003 | 12:54 AM
LxMan1's Avatar
LxMan1
I believe that the shifting in the E4OD is computer controlled. If it has one, then the computer has been reprogrammed with a chip or something.
Jimmy
Old Oct 11, 2003 | 11:31 AM
wildjon300ci's Avatar
wildjon300ci
They also make shift kits...call up one of the manufacturers like B&M and ask them.
Old Oct 11, 2003 | 09:23 PM
LxMan1's Avatar
LxMan1
I know that you usually have to change springs in the valvebody and drill larger holes in the separator plate.
You would probably need new stock springs and a new separator plate to return it to stock.
Why do you want to remove it?
Jimmy
Old Oct 12, 2003 | 08:38 AM
SBelk's Avatar
SBelk
Hi Jimmy,
Actually it isn't me who is doing this. It's my brother who wants to remove the shift kit. I am not sure why he wants to remove it; although I will ask. He just ask me to try and find any information about how to remove it or a layout somewhat about how to do it.
So far you are the only one that has helped me and/or my brother. I mentioned to him about what you said above regarding the computer controlled post and he already knew that. He said he was needing something like a diagram/layout of what has to be done.
If you have any idea, maybe you could email it to me and I could print it out for him.
Thanks for your help.
Sherry
Old Oct 12, 2003 | 11:40 PM
LxMan1's Avatar
LxMan1
I do not have any info on the E40D as to I have never installed on into that particular tranny.
The problem is, is that there are several different manufacturers of shift kits and they all do things a little different. It would be hard to say which one that it has as far as contacting the actual people that made the kit.
I would suggest if he really wants it gone, to either try to buy a new valvebody and separator plate at a tranny shop or junk yard, or find someone with the same tranny that might want a shift kit and trade valvebodies and sep. plates.
Jimmy
jseim44
May 31, 2012 09:33 PM
Rizvi54
Sep 3, 2007 08:40 AM
mustanginca
1983 - 2012 Ranger & B-Series
May 21, 2007 07:18 PM
Jefferys
1997 - 2003 F150
Feb 21, 2005 03:47 PM
