Replacement Bed Bolts
Old Oct 10, 2003 | 08:31 PM
5_labsownus's Avatar
5_labsownus
I just replaced the bed on my 1982 F250 4x4 and had to grind the heads off the bed bolts. When I went to ford, they said; " the bolts are not available! I found out that 1999 bolts are the same. But I looked at a friends F250 King rancher and the bolts are torx heads. Well on investigation I found the the length of the bolts are the same as the 82 bolts, but are completely round! No square holes to round out!
FYI
Rod
Old Oct 11, 2003 | 10:37 AM
drosebrugh's Avatar
drosebrugh
Interesting considering I just torched my '82 3/4 ton bed bolts off to remove the box. Haven't started assembly but will know where to look! Thanks!
Old Oct 11, 2003 | 09:51 PM
bremen242's Avatar
bremen242
what is an F-250 king rancher?
Old Oct 13, 2003 | 12:28 AM
Trqmnstr's Avatar
Trqmnstr
I've never seen a detailed explanation for exactly what a "king rancher" includes...but heres an example of one --> http://cgi.ebay.com/ebaymotors/ws/eB...category=39415
Any time I've ever seen one they seem to be pretty much decked out with options and thats about it.
later!
Old Oct 13, 2003 | 06:42 PM
rander101's Avatar
rander101
For a few years Ford sold F-250 and F-350 models tricked out with a lot of special accessories as a King Ranch model. Sort of like an Eddie Bauer model on steroids. If my memory is correct, the mechanicals were pretty much standard high end options.
RussA
Old Oct 14, 2003 | 09:55 PM
scicop's Avatar
scicop
Don;t know if this helps, but I found some parts I needed from http://www.dennis-carpenter.com/. They have a catalog you can download bsded on the truck year.
SciCop
