Sponsored by: Real Truck
Rear end woe
Old Nov 20, 2019 | 10:29 AM
TxMike82's Avatar
TxMike82
Rear end woe
So, I recently developed a "roaring" noise in what seems to be the rear of my truck (2012 F250 with 6.2 engine and 2WD). The best description I can think of for this sound is similar to what mud terrain tires sound like going down the road. In fact, at first I assumed it was the tires since the previous ones were almost bald but it's still there even after replacing them. I also thought it was the front end at first but after sitting in the bed while someone else was driving it definitely seems to be in the back. It starts making this noise at around 20 MPH and continues from there. In an effort to pinpoint where/what it is I lifted the rear end with jack stands enough to get the tires off the ground, put it in Drive and got it up to about 20-30 MPH; it made no noise at all while doing this but it did set off the AdvanceTrac warning so maybe it wasn't fully letting me do this exercise. Lastly, I pulled the differential drain plug and had to add just a little bit to it which made no difference. Any other ideas?
Thanks in advance!
Old Nov 20, 2019 | 08:48 PM
Colorado350's Avatar
Colorado350
I’d pull the diff cover, clean everything up and inspect the ring and pinion. Order a LubeLocker gasket to replace the RTV sealant under the cover.
xjcamaro89
2004 - 2008 F150
23
Nov 18, 2008 10:20 AM
Bikeitswift
1983 - 2012 Ranger & B-Series
Jun 18, 2008 07:47 PM
frank5
Dec 3, 2006 10:01 AM
hackdog
Dec 26, 2004 09:03 PM
PowerRanger
Nov 24, 2003 08:02 AM
