1 Wire Alternator / regulator Question
I think the questions were already addressed above, but I'll itemize them here:
Most parts stores with an able bodied counter-person could probably just go to the box based on you saying I need a 70a Ford alternator.
They were available in this form from approx. '73 to '92 on cars and trucks, including Broncos and Pickups with the 4.9 engine.
But for general purposes you could ask for one from a '79 Bronco or F150/250/350 and see what comes up.
The most common number (semi-standard industry number) is the #7072 which is clocked at the 9 position. There is a 7072-3 that has the connectors at the 3 o'clock position too. You could look at both to see if one lends itself better to your application, but the standard one was what would have come on your engine. I forget if the clock position is viewed from the back or the front, but you can take one look at it out of the box and know what's what.
The connectors are generally more accessible than the small case, but it's certainly possible to be in the wrong place for any one particular setup. So check.
No, I used my existing one. However, I already had the modern electronic version vs the original electro-mechanical points version. I think that makes a difference and so you should at least make sure your regulator is the modern type.
This is usually indicated by the lower profile of the top cover. If yours is roughly 2.5" tall, it's possibly the old style. If it's about .5" tall, it's the new style. The low profile is a guarantee, while the tall profile is not, since some manufacturers kept the old looking one with new guts for awhile.
Yes.
Depending on the brackets used. I still have not seen a pic of yours, so am not guaranteeing anything. Your results may vary...
Yes.
Used to have them on the electric parts rack, especially if they carried the JTT brand connectors. But I have not seen them as much lately and grabbed one the last time I was in an independent shop that still had them.
Probably the old school NAPA stores might have a good chance of having them. Otherwise they can still be ordered.
Paul
Sorry I did not have the part number for the "pigtail" (connector with wires already) but it's been awhile and I was being lazy in not looking for one. Hmmm, I wonder if I still have one in the package? I'll take a look!
And for the record, when I read your first comment right then, I thought you said that before you were working on the truck, you had a "2-stroke" years ago!
Thought that was kind of a strange comment for this discussion, until I actually re-read it and saw the error of my ways.
good luck. But have fun too!
Paul
If not local, searching that number immediately brought one up on Amazon.
Paul
1- What year or year's was your 70 amp big case for?
2- Did you install a different regulator with this 70 amp unit?
3- Did it fit your existing alternator bracket?
4- Can I get the plug you posted at a parts store?
Anything else please post as auto electric stuff is a bit new to me. Tom
ford390gashog -- I have no problem with my current 65 amp 1G small case alternator, have replaced & upgraded front headlight harness, no flickering. 3G are great for those that need them.
why not stick with what you've got? no need to reinvent the wheel.
if you really just want to switch to an internally-regulated model, just go with a Delco 10si in your existing amp range. super cheap, readily available, very reliable.
rustywheel68 -- True my 65 amp is working out fine as it is correctly. With 85-90% town driving the truck is idling a good part of the time. The large case 1G alternators charge better than the small case at idle. I think this is the way I'll go. Also with my "old dude" eye site I don't drive at night much any more so my battery / alternator draw is very low.
What is the difference between a GR-540-A & GR-540-B?
Will they work with my 65 amp small case regulator on my 1971 F-250?
If a 540-A unit happens to have the tall cover, and on the back of the unit you can see resistors, connections, and all sorts of mystery items hanging out underneath, it's a good chance that it's old-school. An exception to that might be if someone is making them look like the old ones for restoration purposes, but inside is the new solid-state stuff.
But either way, either will work with both alternators. With the solid-state having the advantage most likely.
So stick with the solid-state, in my opinion.
Just so that you have all the info to work with, a 3G is a very good low idle charge unit as well. Just in case you were thinking that the large 1G had any advantage over the 3G in the charging department.
Not trying to talk you into one over the other. Just making sure you have all the info at your disposal.
Paul
540-B regulator & are they both solid state units?
Paul, thanks for the heads up on the 3G at idle charge. If I could find a 3G cheep & wiring was not a big deal I should still look at one. If I have to replace wire harness under the dash that's a big deal. We will see what I come up with.
