Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
fire question
Old Oct 10, 2003 | 12:28 PM
maa139's Avatar
maa139
Question fire question
I don't have an oxy torch, but am in need of some well placed heat. What kind of gas that I can get in the plumbing aisle at the Depot will give me the hottest flame?
Thanks.
Old Oct 10, 2003 | 12:46 PM
dbc's Avatar
dbc
Try MAPP gas it works like propane, only hotter.
Old Oct 14, 2003 | 12:56 AM
Njbmx's Avatar
Njbmx
i work at the depot and the mapp gass burns hot enough to solder. why do you need the torch? btw...the mapp gas in inside the tool corral. (i'm in hardware/tools)
Old Oct 14, 2003 | 09:51 AM
billsco's Avatar
billsco
The MAPP gas burns hot enough to solder? I though propane was hot enough to solder with. Do you mean hot enough to braze with?
Old Oct 14, 2003 | 11:36 AM
dfisher1's Avatar
dfisher1
MAA,
I have used MAPP gas successfully to heat seized bolts. It is much hotter than propane. Its in a yellow can at Home depot.
KingFisher
Old Oct 14, 2003 | 12:57 PM
dbc's Avatar
dbc
Look here:
http://www.cdvkiln.com/popmappa.htm
Old Oct 14, 2003 | 01:01 PM
dfisher1's Avatar
dfisher1
All,
FYI: Propane's heating value is 1,000 BTU/ cubic foot. That means that MAPP has a High Heating Value (HHV) of 2.4 times that of propane. SIGNIFIGANT!
KingFisher
Old Oct 14, 2003 | 01:24 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
what you can do with propane, you can do with mapp. only faster.
Old Oct 14, 2003 | 05:03 PM
Njbmx's Avatar
Njbmx
exactly
Old Oct 22, 2003 | 03:13 AM
Mach1's Avatar
Mach1
Can I burn mapp gas in the diesel? instead of the LP???
Higher BTU rating=More power!!!!
Yes...may have to try it...
Old Oct 22, 2003 | 08:43 AM
95se5m's Avatar
95se5m
This may be a stupid question so please bare with me.
Can you use a standard propane torch tip with MAPP gas? If so, I am golden since I have 2, but if not, what tip should I get?
Old Oct 22, 2003 | 10:15 AM
dbc's Avatar
dbc
Standard propane tips work fine. On another note, anyone out there have any experience with hydrogen torches?
Old Oct 26, 2003 | 07:35 PM
billsco's Avatar
billsco
95se5m,
My understanding of MAPP vs propane is that you CAN'T use a propane tip on MAPP. There are tips that can burn both for sale nowadays but the old propane tips frequently found on top of a blue bottle in someone's shop are not up to the hotter temps.
Old Oct 28, 2003 | 03:47 PM
$trokin60's Avatar
$trokin60
I have found that a turbo torch seems to burn hotter than a cheap $ 15 benzomatic from wal-mart or home depot they can usually be found at plumbing supply stores and they burn map gas as well I've seen people do silver solder with them which requires a hotter flame than regular solder
Havecooker
Apr 9, 2017 11:07 AM
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
jasonschwenk
New York Chapter
Nov 27, 2006 07:35 AM
