1978 - 1996 Big Bronco
95 Front Seat Replacement
Old Nov 18, 2019 | 12:11 PM
quinletc's Avatar
quinletc
First, hello Bronco fans! I am a long-time Ford truck owner, and I've been active at times in other forums on here - the bumpside and the 2009-2014 forums.
I just bought my first-ever Bronco, a 1995 Eddie Bauer, 5.0L. High-back bucket seats.
The driver's seat is in pretty bad shape. The leather on the seat bottom is almost totally gone, though the foam is mostly intact - PO had a slip cover over it.
The recline-release mechanism is broken, but the seat frame itself also appears to be broken - held together with some light steel strapping and bolts.
The forward-rear adjustment works just fine. It's manual, not electric.
Are there any more modern Ford truck truck seats that are known to fit the last-gen Bronco? I'm thinking of keeping the lower frame and rails and just swapping out the seat itself.
Thanks!
Old Nov 19, 2019 | 10:14 AM
CZ Eddie's Avatar
CZ Eddie
https://www.fullsizebronco.com/threa...-covers.74449/
Old Nov 26, 2019 | 12:34 AM
Coveredwagonoverland's Avatar
Hi! Welcome.
youve got a couple options depending on your ability with a welder and if you want to drill and plug holes. I’ve seen a few with expedition seats, but if you get the electrical adjustable you’ll need some wiring skill, there have been one or two out there with 2005+ f-150 bench seats that I’ve seen as well.
personally I have the same issue, but I like the seats that came with it so I rock duct tape and a Cabela’s seat cover. No issues. If you want to keep your stock seats just hit up local reupholster shops, when I did my last pair I think I paid $100 a seat and they came out feeling and looking brand new, without having to spend hours aligning the rails and wiring.
hope that helped 👍
Old Nov 26, 2019 | 07:07 AM
Lowdog's Avatar
Lowdog
Is there any reason the front buckets from the same year extended cab wouldn't work?
Old Nov 26, 2019 | 10:05 AM
Should fit but I’ve never tried it personally, I like the neck support in case of a crash 🤪
Old Nov 26, 2019 | 11:04 AM
fodder2's Avatar
fodder2
The '92-96 (and '97 OBS) seats will fit. The 40/20/40 seats are a popular drop-in swap for that reason.
Old Nov 26, 2019 | 06:54 PM
Lowdog's Avatar
Lowdog
fodder2, glad to hear that. I thought they looked the same. That is good news as I just bought a decent set for my Bronco. You hear that quinlect ? There is a place that sells replacement covers for the original seats which would put you back to original unless you just want modern seats. The name of the place is Remington, they are in Texas. I haven't used them but plan to for my seats.
Old Nov 27, 2019 | 06:24 PM
Bruners4's Avatar
Bruners4
I picked up a bottom cover and a set of armrest cover from Richmond.
https://leather-auto-seats.com/produ...y/ford/bronco/
I've rebuilt a couple of seats and armrests using parts from other seats that I've picked up here and there. I desperately need new foam for my driver's seat bottom.
Old Nov 28, 2019 | 06:13 PM
Lowdog's Avatar
Lowdog
My bad it's Richmond
Old Dec 2, 2019 | 04:26 AM
WhëëlMå1's Avatar
WhëëlMå1
If you source sets from a truck, I believe the seat pan is the same in the extended cab only, for the bronco. The regular and crew cabs are interchangeable with each other, but not the bronco as-is.
Old Dec 2, 2019 | 10:19 AM
fodder2's Avatar
fodder2
The bolt patterns are actually different? I thought it was just that the non-extended cab seats don't have the extra slider extension for easy rear access, but maybe I misunderstood.
Old Dec 3, 2019 | 01:02 PM
Kemicalburns's Avatar
Kemicalburns
I found early 90s mustang seats and bolted them to the bronco seat frames. works like a charm. Explorer seats and expedition seats will also fit.
calzone
Bronco II
Apr 19, 2022 04:03 PM
v8xploder
1966 - 1977 Early Broncos
Sep 27, 2006 10:27 PM
Aggie05
Bronco II
Mar 29, 2006 10:46 AM
Mil1ion
Jan 6, 2003 09:36 PM
Ford79
Apr 7, 2000 10:00 AM
