Check Engine Light
Old Oct 10, 2003 | 09:31 AM
Jon Fenton's Avatar
Jon Fenton
Question Check Engine Light
I have a '96 Explorer with 75,000, CEL just came on. I had emissions tested for new tabs and the next day CEL came on. I don't really want to go to a dealer. Is thier a good diagnostic tester that I can by cheaply to diagnose problem. I have not notice any symptoms. Could my emmissions test have any thing to do with it. Any good brands for code tester? Can a novice operate one.
Thanks for any help.
Old Oct 10, 2003 | 10:43 AM
mrshorty's Avatar
mrshorty
There may be others, but I know Harbor Freight sells an OBD-2 code reader for ~$50. It won't do anything more than pull trouble codes. You could get a scanner, but that will run you at least $150 and probably more. You might try a parts store. Some (Autozone in particular) will read trouble codes for free, and then tell you what part(s) you need to buy to make the code go away. I wouldn't buy anything based solely on the trouble code, but it would be a cheap way to get the trouble codes.
Colorado Horseman
Jan 5, 2017 07:25 PM
Telestar
45
May 4, 2016 06:35 PM
William
Jan 30, 2016 04:57 PM
Hank85713
Modular V10 (6.8l)
Oct 12, 2015 06:04 AM
1992FordF150Custom
19
May 25, 2014 01:03 PM
