Clutch boot ???
Old Nov 14, 2019 | 08:27 AM
xtal_01's Avatar
xtal_01
Clutch boot ???
Well I am learning ....
I remembered in the picture you guys sent me to for the clutch bolts, it also showed the bellhousing.
Went to the picture and sure enough there was the clutch fork boot # 7513
So I search it ... turns out there are a lot with that number .. but finally got the full number .... E4TZ-7513-A (I think this is right).
So, started searching ... first the usual .... Rock Auto, Amazon, Advanced, Autozone ... then Ebay ... then RearCounter and PartsVoice
I am getting nothing! On the Ford sites, it just says discontinued.
With so many of these out there, I figured someone must be making them?
Any suggestions?
Mike
Old Nov 14, 2019 | 09:40 AM
FuzzFace2's Avatar
FuzzFace2
The boot goes by the transmission so what one do you have?
If a T18 good luck as I could not find one.
Dave ----
Old Nov 14, 2019 | 10:25 AM
xtal_01's Avatar
xtal_01
There is only one listed for all transmission I think. Just where the clutch forks go into the bell housing.
I have a 435 4 speed.
Mine is still there but after 33 years, I know it could use a new one ... just trying to keep all the crap out of the bell housing.
All the listings seem to stop at 1982 ... and I have a 1986
I was hoping someone was manufacturing new ones.
Mike
Old Nov 14, 2019 | 12:54 PM
marksman76's Avatar
marksman76
I bought a new one a few months back for my 1996 M5.
It was in Ford packaging, but a Mazda part.
Old Nov 15, 2019 | 12:06 AM
FuzzFace2's Avatar
FuzzFace2
There is not 1 fits all but all you can get is 1 and they don't list what it fits IIRC.
I say this because I bought one think thru Dennis Carpenter and it doesn't fit my T18 bell.
Dave ----
Old Nov 15, 2019 | 03:38 AM
Ken Blythen's Avatar
Ken Blythen
I've been trying to find one for several years (1983 mech. linkage truck), but can only find the one mentioned. Finally I bought two of those, trimmed both & super-glued them together at 90 degrees to each other to get a fit of sorts......not ideal but what do you do?
Like the OP said, "with so many of these out there"...........?
Old Nov 15, 2019 | 06:59 AM
FuzzFace2's Avatar
FuzzFace2
Ken, I may give that a try as I have nothing .
Dave ----
Old Nov 15, 2019 | 07:29 AM
xtal_01's Avatar
xtal_01
Great idea!
May try glue ... or even glue and a few screws like a CV joint.
Thanks!
Old Nov 15, 2019 | 05:55 PM
Ken Blythen
To get a complete join, I added a couple of pieces of o-ring material when I glued it together.
Old Nov 15, 2019 | 08:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The boot goes by the transmission...
With the following part number, the type of M/T makes no difference.
E4TZ-7513-A .. Clutch Release Lever Dust Shield / Obsolete
1984/89 F150/350, Bronco & Econoline.
No Ford dealer or obsolete parts vendor has any, none on ebay.
Upper/Lower pics: See 7513 for other 1980/89 dust shields...
1983/87 6.9L & 7.5L with T-19 is different
Ctjkre
Jun 6, 2019 06:33 AM
Schickel
Aug 4, 2013 02:20 AM
Jeff Van Housen
Nov 2, 2005 01:32 AM
Franken-Truck
Aug 7, 2004 11:42 PM
bob-63-292
13
Nov 13, 2003 07:58 AM
