oil in radiator
Old Oct 9, 2003 | 10:41 PM
redranger1's Avatar
redranger1
oil in radiator
hey guys, im lookin to buy an 89 f-350 with the 7.3 deisel. it has 140k miles and they claim it has great compression. the problem is that the radiator is full of oil and they claim it is because the oil cooler is leakin. by the way, it is a 4x4 w/ a 5 speed and a dump bed and the truck is in decent shape, is it worth $4500? thanks.
Old Oct 9, 2003 | 10:50 PM
argve's Avatar
argve
Well it could be the oil cooler orings, but it could also be cavitation.
When mine failed for cavitation I had water in the oil, and oil in the water and she hydrolocked. The good compression is not a full proof test, because if the pin holes occured lower in the cylinder then it would still show good compression.
I would say keep looking. there are other trucks out there. Or have them come down quite a bit. A remanned long block will run you around 3-4k when your all said and done.
Old Oct 9, 2003 | 11:52 PM
Spectramac's Avatar
Spectramac
Don't buy it unless you can afford to replace the engine. Around 5 grand.
Old Oct 10, 2003 | 05:44 AM
pnose's Avatar
pnose
turn around and run as fast as you can$$$$$. DONT LOOK BACK!!!!!!!!
Old Oct 10, 2003 | 06:17 PM
redranger1's Avatar
redranger1
so you guys are tellin me that i shouldnt buy it eh? i decided to try and jew him down to $2000. the drive train and body is worth at least that, and thats what im wantin anyhow.
Old Oct 12, 2003 | 03:33 PM
Greywolf's Avatar
Greywolf
The last time I looked at a machine that had oil in the radiator, the dipstick turned out to be covered with something that looked like mud.
The one in the engine, and the one trying to sell it to me...
I hope you have a line on an engine, I wouldn't try to drive it two feet.
