Did some searching here but using google` was much easier. This is on a 1997.
Did a little testing because my driver's window wouldn't work - up or down. Seems the GEM module is prone to failure. I found this video that makes it so easy to bypass. You do lose the auto-down function but to me it was worth it.
Does this just take GEM out and do all other door functions work fine? If so, anyone who wants to add power door should take this path instead of wiring the doors directly. Neat!
