Winter is here..... now what?
Old Nov 8, 2019 | 01:31 PM
6.9IDIot's Avatar
6.9IDIot
As some of you may have heard we finally got our snow here in Wisconsin and that's a pretty good sign that we are done with the warm weather. Every morning this week when I've gone outside it has been around the 15-25 degree range. Do you guys have any recommendations for my 6.9 this winter as it is my first winter with her? Should I get one of those quilted grille covers for it? Also the truck was made in January of 85' so I am reluctant to test my luck with the block heater, but it does have an aftermarket lower radiator hose heater in it, should definitely start plugging that in I'm guessing. Would that be an all night leave it plugged in or maybe just plug it in 30min before I leave in the morning?
Old Nov 8, 2019 | 03:08 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I would put the block heater that is in the lower Hose on a timer, set the timer for 2 or 3 hrs before starting.
blanket to cover hood area is never a bad thing assuming it is out in the open, back in the Early to mid 60's we used to use a dipstick heater too... I was in North Dakota back then (dip sticks were a straight shot on most vehicles back then too) I think they make a magnetic pan heater nowadays but I haven't looked much as we don't need any such things here in Texas
Old Nov 8, 2019 | 06:38 PM
tjc transport's Avatar
tjc transport
i ain't rite
if you are going to use a grill cover, invest in a good mechanical coolant temp gauge and pay close attention to it. it is very easy to overheat the engine with the grill blocked off, even in freezing temps.
Old Nov 8, 2019 | 07:04 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Amen to that.... when I said blanket I of course meant just an overnight thing LOL
BUT I do remember we often used a piece of cardboard in front of the radiator to help the heater out and it didn't block the whole radiator just a small area.
Old Nov 8, 2019 | 10:29 PM
DarkOverCast's Avatar
DarkOverCast
I used to use a home depot Christmas light timer (15$) for mine, it was programmable for seven different days of the week. I let it kick on 3-4 hours before I needed it and it worked like a champ.
Now I use an ether start kit with refills available at any auto parts stores (or John Deere dealer) and keep a spare can understand the seat. I normally buy deeres 80% stuff works real good and just a bump of the button is all it takes. Been on roughly two years and compression was up to par six or so months ago.
Old Nov 8, 2019 | 10:59 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I still have a couple of the old Lincoln k887-1 Kits... I bet they could be adapted pretty easily
Old Nov 9, 2019 | 08:41 AM
RaymondIV's Avatar
RaymondIV
The weather fronts (grille covers) seem to be optional, I don't see many, I've never needed one and our temps can get 10° below zero. On the other hand, a friend had an early Power Stroke 7.3 and he used one every winter. As far as plugging in the block heater, make sure the timer can handle 1200-1500 amps and 2-3 hours has always been enough for me.
Old Nov 9, 2019 | 01:08 PM
Charmalu's Avatar
Charmalu
I throw a HF Moving Blanket over the engine when I use the Block Heater,
Really holds in the heat. Be sure to remove it before starting the engine.
I find the Mice like the warm cozy area also, throw in a couple traps.
An Oil Pan Heater would be a good add on, I don`t see it mentioned, but
the oil gets pretty thick and warm oil will get to the vital parts sooner.
Here is a Google search on Oil Pan heaters if some of you don`t know
what they are.
https://www.google.com/search?q=oil+...=1573325808366
I read one comment where the guy thought the Engine Block Heater warmed the oil.
I didn`t know heat went down hill....HMMMM. Any way, to each their own.
Now that I got off my procrastinating **** and finally hooked up my GP`s to a manual
switch, amazing how well the engine starts in the mornings. We have been down to the
high 20 to low 30`s at night, and 67 - 70 in the days the past few weeks here in the
Carson Valley south of Reno. I feel for you guys back east with the snow already.
Guess I`ll thrown on some more Sun screen.
Charlie
Old Nov 12, 2019 | 11:01 AM
Olds64's Avatar
Olds64
If you decide to use an ether start kit make sure you never mix GPs and ether. I only ever need to use my GPs but it doesn't get too cold in OK (25* the past few nights).
59INA40
Nov 16, 2011 09:25 AM
brown 4x4
Nov 29, 2007 06:45 AM
MarkMoore
Modular V10 (6.8l)
Nov 5, 2006 10:22 AM
sturoe
Nov 3, 2006 03:13 AM
Quinny
1983 - 2012 Ranger & B-Series
Nov 2, 2005 08:42 AM
