Transmission growling
Old Nov 8, 2019 | 06:25 AM
99FORD EXPY.'s Avatar
99FORD EXPY.
so i have a new issue , the transmission is growling in drive mode and manual mode, that said it only does it at 10 MPH that i can hear. In manual mode from a dead stop it is very noticeable. The truck drivers fine all shifts are normal. your input would be very helpful.
note: all past tbs have been completed years ago .
Thanks
Old Nov 8, 2019 | 07:50 AM
UP_There's Avatar
UP_There
I'm not sure of the fix, but my advice would be to park it immediately, and trailer it to the shop. These transmissions are far too expensive to chance making it worse.
Old Nov 8, 2019 | 07:52 AM
Overkill2's Avatar
Overkill2
Thanks
To help out more knowledgeable guys, what year truck, mileage and maintenance done?
Old Nov 8, 2019 | 07:56 AM
99FORD EXPY.
2011 f350 all regular maintenance has been performed as normal no heavy Towing 139000 miles
Old Nov 8, 2019 | 07:58 AM
Overkill2's Avatar
Overkill2
Did you ever change out the trans fluid at all?
Old Nov 8, 2019 | 08:00 AM
99FORD EXPY.
Yes 3 times , Drain infill with a new filter each time
Old Nov 8, 2019 | 08:02 AM
Overkill2's Avatar
Overkill2
Okay good. You were maintaining the additive package in the fluid. Some of these trans have issues with solenoids. Any codes? You try a code reader?
Old Nov 8, 2019 | 08:48 AM
99FORD EXPY.
No codes at all and Ford did all the service work , fluid and filter changes at 50k each time and this last time 10k ago at 120k ALL FLUIDS WERE CHANGED, and I do mean all fluids front to back
Old Nov 8, 2019 | 06:51 PM
99FORD EXPY.
just to clarify , the issue is only in first gear both drive or manual , I'm hopeful that someone has at least heard of this type of issue before i have to go to ford.
Thanks
Old Nov 8, 2019 | 08:33 PM
senix's Avatar
senix
perhaps a pump or the torgue converter.
Old Nov 9, 2019 | 03:58 AM
99FORD EXPY.
that sounds $$$
thanks
Old Nov 9, 2019 | 05:39 AM
senix's Avatar
senix
could be way off but that is my thoughts.
ssunit1
Jun 29, 2018 07:31 PM
Jumbo131
6.7L Power Stroke Diesel
Oct 10, 2013 07:36 PM
fordtruckf-100
33
Jan 12, 2012 09:57 PM
Paclik
Apr 1, 2005 09:50 AM
