Sponsored by: Auxito
FORScan help
Old Nov 7, 2019 | 09:57 PM
GRokDevine's Avatar
GRokDevine
FORScan help
2002 F-150 4.6L V8 4x4 5spd
I have a 97 that I'm going to tinker with too. Has anyone else messed with this gen 150 on FORScan?
are there any other options to fix the speedo? Is it worth buying a programmer?
I've got FORScan running on my laptop (Win7) updated to the latest version and got the extended license.
Now I can read/clear the codes. I can see pages of data about my truck, but I have not been able to make any changes. Any changes I make in the "As Built" section have no effect. Anything I change in the other section tells me "No changes in block ******, skipped". It only gives me the RAP and GEM modules and only one line each.
Changes I would like to make.
Tire size - I upgraded my tires from the stock 255/75R17 to 315/75R16 now my speedometer is off 5+ mph. Which means my mileage, and in turn my mpg.
Delete the seat belt ding!
Yeah I have a few problems, also it is throwing a bunch of codes that are just annoying...
- less than 2 transmitters programmed
- battery voltage is fine (new alternator/battery) but GEM B1318
- apparently I have a problem with my transfer case
- I get a short in the heater circuit when I run more than 150 miles/day
Diagnostics shows my odometer at 327k miles but my dash only shows 203k
Old Nov 16, 2019 | 12:45 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I haven't done much with Forscan yet, but I know I've seen others do stuff with Forscan on vehicles from yours' era. I'm going to be messing with my `99 when I have the time to do it right . . . and carefully. If you haven't already, you might want to bulk-search for Forscan in the forums then look through the results and find similar vehicles. A little tedious, but I think it will get you some others who have Forscanned similarly-aged vehicles.
Old Nov 26, 2019 | 12:29 PM
geo6x's Avatar
geo6x
Your odometer is ok....Forscan is giving you the reading in kilometers. 327,000 km = 203,000 miles.
BillyE
Dec 26, 2018 07:52 PM
GASPIG88
Bronco II
Feb 18, 2018 09:02 PM
RussEx
Feb 9, 2015 09:05 PM
Herbandskills
Jun 22, 2012 10:17 AM
brownie83
21
Jul 25, 2011 08:19 PM
