shock mount brackets..
Old Oct 9, 2003 | 08:35 PM
allv8fords's Avatar
allv8fords
i need the rear shock mount brackets to my 82 f 250 4x4.. the ones that attatch to the frame one of mine has broken at end taht holds the shock.. i cant find ant other than the local bone yard or the dealership.. and if the stocks broke than someone has to have bigger and better..
Old Oct 10, 2003 | 04:57 PM
bremen242's Avatar
bremen242
The stock ones broke because they hold crap in that little cup where the shock is mounted, and it rots out. go to the dealer, because they are around $12. Cut off the rivets and bolt it back on with grade 8 bolts. it'll be good for around 15 years.
Old Oct 10, 2003 | 08:24 PM
5_labsownus's Avatar
5_labsownus
If the dealer tells you that they are not available go up in body style. They are the same! So are the spring hangers!
Old Oct 10, 2003 | 09:38 PM
82F100SWB's Avatar
82F100SWB
Yup, go in and ask for parts for a 97 F250 or F350, last year for the 80-96/7 chassis. For the most part, the 99+ Super Duty chassis looks quite similar, however, I haven't done a side by side comparison. I do know that they use the same cab mount bushings, they even carry an E0(1980) engineering number.
Evan
Old Oct 11, 2003 | 08:23 PM
5_labsownus
I looked at a 2003 F250 very close and then looked at my truck next. A lot of the rear hardware looks very close! I need to get a tape out and check!
Old Apr 9, 2007 | 08:11 PM
AlbraiNYa's Avatar
AlbraiNYa
lmc truck has them for 16 bucks a side
