Looking for seat covers that are easy to take on and off I would only use when hunting and then take off, wash if necessary and store until the next hunting trip. Looked at Carthart but would like to know if they are easy to install and remove, also anyother brands you have used.
I only got one for the driver's side, as I often get in with dirty work clothes on. I've had it since Nov 2017. It's showing some wear, but I use it a lot. No problem getting in or out, just check to make sure it is setting on the seat where it should be before sliding in.
Perfect, that’s all I wanted too, thanks for the other info too.
I have the Carharts, but I don't take them off. They fit pretty snug, and took a bit of effort to get on. You would probably be happier with something looser like those mentioned above if you're taking it on and off. With that being said, I love the Carhart covers. They don't move around at all, feel pretty comfortable, and look brand new after a year of daily use.
Carhartt are great just not right for what I need. I bought a slip on canvas cover that should do the trick
