Sponsored by: Real Truck
Sticky Supercab Door
Old Oct 9, 2003 | 04:05 PM
harria3's Avatar
harria3
Exclamation Sticky Supercab Door
Drivers side supercab door sticks closed a lot. Trying to open it with the handle in the door frame will semi-unlatch it, so the door will be in the same position as if you didn't close it hard enough. The handle on the inside of the cab works all the time though. If I use the frame handle and it sticks, the interior handle will open it, but it's very sticky, and is obviously grabbing something internally that the frame handle is slipping on.
Dealer couldn't recreate it, and just sprayed some lube in, but that didn't help.
Any ideas?
Thanks a lot.
-Andy
