Scanner can't connect to Ecm
Old Oct 29, 2019 | 12:01 AM
homertwo's Avatar
homertwo
Hello
I took my 2000 F550 with a 7.3 to a shop today. I wanted him to check on my pressures.
When I went in to talk to him later, he said that his Snap On scanner can't connect to get into the ecm to check the pressures.
I have Forscan on my laptop and I can get in and do some tests and other things so I don't understand why his scanner can't get in. He said he could get in to the Gem and the Abs.
Any thoughts or reasons you may have from experience?
Thanks
Old Oct 29, 2019 | 02:38 PM
Colorado350's Avatar
Colorado350
Have you tried Forescan AFTER he tried? Could be as simple as the fuse.
Old Oct 29, 2019 | 10:37 PM
kbeefy's Avatar
kbeefy
If he can get to the GEM and ABS then the DTC port should have power.
I know some superduties don't like my snapon verus pro scantool. Sometimes retrying works, sometimes I have to grab a different scanner.
Old Oct 29, 2019 | 11:16 PM
homertwo's Avatar
homertwo
I can get in with Forscan. He can't get in with his Snapon. He has tried on more than one day. What fuse are you talking about?
Thanks
Old Oct 29, 2019 | 11:27 PM
kbeefy's Avatar
kbeefy
I believe it's the fuse for the cigarette lighter, but it's probably good as I stated above.
chewtoy
Oct 19, 2019 03:51 PM
JesterPgh
16
Mar 1, 2009 09:42 AM
BURNSTOUGHFORD
1997 - 2003 F150
May 6, 2007 11:44 AM
malbojah
1997 - 2003 F150
May 28, 2005 07:00 PM
