Cab mount question day ...
Old Oct 28, 2019 | 07:52 PM
blue351's Avatar
blue351
Went to order cab a mount bushing kit for a 79 f150 reg cab 4x4 . The question came up as to the difference between cab mount bushing kit for 4wd vs 2wd.
The people I was going to order it from didn't know the difference. But, apparently there is a difference in the kit not to mention the fact that the 4wd kit is almost
100.00 more. Was wondering as well , if the preference is for rubber bushings or poly bushings. The body shop guys are recommending using the rubber if
I can get them. while im at it , who has the best deal on a kit for 4wd 79 ?
Thanks in advance for the help
Old Oct 28, 2019 | 08:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Genuine Ford Parts:
1975/79 F100/350 Regular & F250/350 Crew Cab front and rear body mounting parts (upper & lower rubber absorbers & hardware) are the same. 2WD or 4WD makes no difference.
1978/79 F100/350 Regular/Super/Crew Cab front cab mounts (D8TZ-5077-A R/L same) are the same, 2WD or 4WD makes no difference.
Aftermarket parts should not be any different, but these parts most likely do not match the originals. The parts I've seen are "universal fitz-alls."
Old Oct 29, 2019 | 06:00 AM
gijazbo's Avatar
gijazbo
Yup, like above I bought mine aftermarket. If I recall I got them from LMC truck. That were good quality, but buy the new bushings too because you will surely destroy them getting the old rubber off.
Old Oct 29, 2019 | 12:10 PM
John89's Avatar
John89
Depending on your plans/needs for your truck, consider getting a complete kit.
I got an Energy Suspension kit from Amazon for about 140.00
Old Oct 29, 2019 | 12:13 PM
John89's Avatar
John89
The price difference you were quoted may have been for a complete kit. 4WD kit would have C-bushings and track bar bushings while the 2WD would not.
Old Oct 29, 2019 | 08:00 PM
NumberDummy
The OP is asking for cab mount bushings and related parts, not suspension parts.
Old Oct 29, 2019 | 08:17 PM
John89's Avatar
John89
I know, but my master kit came with cab mount bushings included.
Old Oct 30, 2019 | 12:37 PM
blue351's Avatar
blue351
the bolts backed out fine. I was surprised they didn't break. problem like gijazbo said, the bushings just spin and I suspect they break in pieces if we try
to break them loose.
so the amazon / energy kit has everything in it ?
Old Oct 30, 2019 | 02:40 PM
John89's Avatar
John89
Check out energy suspension website and look up your application. See which kit you want and search for that number on Amazon or eBay. The pictures of the kits are pretty good about showing what is included.
My master kit included:
C bushings
Core support bushings
Cab mount bushings
Track bar bushings
Radius arm bushings
Rear leaf spring bushings
Tie rod end caps (didn't use)
and some hardware (inserts and shims/washers) I think that was all.
If some of those bushings don't need to be replaced, you can kinda mix and match by selecting a different kit.
Old Oct 31, 2019 | 02:43 PM
blue351's Avatar
blue351
Genuine Ford Parts:
Bill,
according to carpenter - there is a difference - they don't have a 4wd kit which makes no sense if ford says 4wd and 2wd are the same. They (carpenter)
suggest that the difference is the length of the bolt ? any ideas on that ?
Thanks
Carpenter Part #: D3TZ-5400-S
Old Oct 31, 2019 | 03:11 PM
NumberDummy
Originally Posted by blue351
Bill,
Thanks
Phoney-baloney Carpenter Ford part number.
1973/79 pic of Body Bolt Locations: Number 1 is the front cab mount parts, Number 2 is the rear cab mount parts.
Absorbers are the rubber cushions. Do you see 4WD anywhere?
emeraldcoupe
Mar 21, 2019 02:53 AM
crfly
Nov 22, 2018 02:18 PM
KsCop
Aug 6, 2013 09:23 PM
Beefcake09
Jul 16, 2009 11:00 PM
msmyth
Nov 24, 1999 11:49 AM
