88' Wheel Seal
Old Oct 28, 2019 | 10:59 AM
yellercat's Avatar
yellercat
88' Wheel Seal
Got a difference on my front inside wheel seal housing diameter and looking for some guidance if anyone else has had similar observation. The prescribed seal has a inside diameter of 2 inches which is fine. The housing diameter is 2.63 and mine measures closer to 2.4 inches so its a no go. Of course the old seal was discarded and at a loss as to which other lip type seal will fit. These are the seals that fit inside the dust shield. Someone surely switched this truck's at some point is my guess. Any ideas as to what may fit these mystery shields? TIA
Truck is an 88' 2 wheel drive F-150 with the six cylinder
Old Oct 28, 2019 | 11:52 AM
88n94's Avatar
88n94
Does this seal go into the hub? If so take the hub to the parts store and have them fit it with a seal, you know the inside diameter is 2 inches.
Old Oct 28, 2019 | 12:06 PM
yellercat's Avatar
yellercat
The outside 'lip' of the seal fits behind the dust shield, and the dust shield faces the hub. Probably would take the dust shield in to fit with a 2" inside diameter seal. Not sure how many of our trucks use this type of seal.
Old Oct 28, 2019 | 12:37 PM
yellercat's Avatar
yellercat
Maybe I have this wrong. Going by what was disassembled and remember the seal being in the back side the dust shield.
The seal DOES go into the rear of the hub ok. Perhaps it should be against the dust shield after bearings are fitted?
Need a parts diagram to see. Possibly work either way?
Old Oct 28, 2019 | 12:42 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by yellercat
The outside 'lip' of the seal fits behind the dust shield, and the dust shield faces the hub..
That is not correct.
Maybe I have this wrong. ?
Yes.
Dust shield goes against the knuckle first. The seal is driven onto the the back of the hub after installing the inner wheel bearing. Then install the rotor onto the spindle.
Old Oct 28, 2019 | 12:46 PM
yellercat's Avatar
yellercat
Yep, had it totally wrong. Thanks for the knock on the head My4 !
Gotta' refrain from using that memory too hard.
zapola6
Jun 20, 2017 09:25 PM
truckmen
16
Aug 5, 2015 06:44 AM
triskit16
Jan 2, 2009 05:39 AM
69ford99
1978 - 1996 Big Bronco
Nov 22, 2006 01:28 PM
RhinoScores
Sep 8, 2006 08:17 PM
