1978 - 1996 Big Bronco
Transmission problems
Old Oct 27, 2019 | 09:27 PM
Hedrick's Avatar
Hedrick
I put a 1992 full size Bronco 4x4 E40D transmission in a 1995 Ford F-150 4x4 1/2 ton truck and everything bolted up but wiring on passenger side for shift valve plug was different so I took wiring harness from shift valve plug up underneath brake booster off and swapped with 92 Bronco but Bronco has 4 wires on one plug and 95 has 3 wires on one plug and it’s the little round plug not square one under brake booster and truck runs but won’t shift out of second gear! The reason I changed transmission is overdrive was out and shift valve was bad on 95 F-150 and 92 Bronco transmission was good! Can someone please help me!
Old Oct 27, 2019 | 10:33 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
tadkins
New Member Introductions
Feb 13, 2008 10:36 PM
