Sponsored by: Real Truck
Angie
Old Oct 25, 2019 | 03:06 PM
Angie Arndt - Sills's Avatar
Angie Arndt - Sills
Angie
Hello group, was recommended to touch bases. We have a 99 Ford F-350 2WD Super Duty dually. Low gears. We currently use to haul travel trailer. At 65 mph rpm at 2200. Would like to know what gear ratio is better for fuel and rpm, than towing power. The tag on side door has tr 6 if that helps and we have a zf6. All recommendations would be helpful.
Old Oct 25, 2019 | 04:18 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
The folks that know about this kind of thing don't usually frequent the "New Member Introductions" forum. You might might want to post in "1999 to 2016 Super Duty" to get some answers flowing. When you do, it would help to know what kind of engine you have and how big and heavy your trailer is.
Welcome aboard!
Old Oct 25, 2019 | 06:01 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE.
Also check out the towing forums and don't forget you local state chapter.
Old Oct 27, 2019 | 09:06 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Oct 27, 2019 | 10:41 PM
Colorado350's Avatar
Colorado350
‘Welcome to FTE.
Im assuming you have the 7.3L. There should be a tag on the rear diff that should have numbers on it. You’ll most likely see 3.73 or 4.10 with a L or LS for limited slip. Considering you have a 2wd and a ZF6 you’re already set up perfectly for fuel assuming you mean mpg and rpm. The 7.3L can run all day long in the 2300-2800 rpm range without doing any damage. The lower gearing again assuming you have 4.10’s will only help you from a towing POV. There’s other things you can do to increase the efficiency of your engine.
I have a 99 F350 2wd Dually (7.3L) auto, I regeared from the 3.73 to 4.10’s and added a Truetrac, my towing rpm’s only increased around 200 and I lost maybe 1-2 mpg. However, I would never go back to the 3.73’s for a tow rig!
Old Oct 28, 2019 | 05:30 AM
senix's Avatar
senix
If you are not towing then I guess you could regear it to 3.73 (if you have the 4.10 or maybe even 3.55.
But all of this will also mean you may have to downshift to keep your speed up.
If you have plans to tow in the future then I would not change any gearing.
Old Oct 28, 2019 | 09:35 AM
Batman7777's Avatar
Batman7777
Ford 7.3 Diesel Power Band: https://www.ford-trucks.com/forums/6...-of-7-3-a.html
Old Oct 28, 2019 | 10:16 AM
Pickupmanx2's Avatar
Pickupmanx2
I have an '02 F350/4x/DRW/CC/Auto/4.10's, I avg. 11-12 towing, 13-15 empty, I have a Hypertech programmer, it increased Tq, mileage and the fun factor, I also have cone filter and 4" turbo down, no muffler.
My Excursion 4x, same set-up exactly but with 3.73's is only about 2-3 mpg better towing and empty. Not worth the cost to re-gear to me... if ya wan't good mileage, buy a 1978 Fiesta! we had a few of those and they got 35-40 all day long, and were fun as hell too!
ScottKlajic
Jun 20, 2019 12:39 PM
Jasom
May 10, 2019 01:02 PM
Hapycmpr
May 18, 2018 08:07 AM
Loopy151
Apr 30, 2018 05:31 PM
AntichristDieZel
Apr 15, 2018 02:02 PM
