Sponsored by: Real Truck
Surlasic Shackles
Old Oct 22, 2019 | 07:55 PM
dzdiggin'dude's Avatar
dzdiggin'dude
Surlasic Shackles
Anyone running these on an older Superduty? Read about them on a newer SD and wondering if they would be good for a 99 SD ?
Old Oct 23, 2019 | 07:33 AM
oharal's Avatar
oharal
Do a search and you'll find more as people ask about these every month or so. The general consensus is they work, but don't make a huge difference. It does introduce another component that will eventually wear out as well.
Old Oct 23, 2019 | 09:32 AM
Overkill2's Avatar
Overkill2
https://www.ford-trucks.com/forums/s...rchid=29026726
You're welcome.
Old Oct 23, 2019 | 07:05 PM
dzdiggin'dude
Overkill your link did not work. I did a search that did not net anything. Thanks.
Old Oct 23, 2019 | 07:30 PM
Overkill2's Avatar
Overkill2
Hang on. I did it on my phone which I'm on now. Give me a minute.
For one, you're spelling it wrong. It's SULASTIC.
Old Oct 23, 2019 | 07:43 PM
Overkill2's Avatar
Overkill2
Old Oct 24, 2019 | 05:08 AM
dzdiggin'dude
Thanks for the links and the spelling lesson.
Old Oct 24, 2019 | 07:19 AM
Overkill2's Avatar
Overkill2
No problem. Let us know here what you decide to do.
Old Oct 24, 2019 | 10:38 AM
2012F2Fiddy's Avatar
2012F2Fiddy
4wd High
I had them on for about a year and it maybe lessened the harshness by 10%. I just took them off and upgraded to PMF/Deavers with a 4.5" lift built in and it's better than Sulastics on Skyjacker "softride" leafs for sure
Old Oct 24, 2019 | 01:44 PM
seventyseven250's Avatar
seventyseven250
Would the Roadmaster Active Suspension be an option?
Old Oct 24, 2019 | 09:24 PM
Bently_Coop's Avatar
Bently_Coop
@seventyseven250 the RAS is for rear suspension, Sulastic is a drop shackle with a large bushing for the front suspension.
Old Oct 25, 2019 | 09:01 AM
seventyseven250
Wow, I think I need to drink an extra coffee before I post. Thanks for straightening me out.
Old Oct 25, 2019 | 11:21 AM
Overkill2's Avatar
Overkill2
That's a negative... they are for the REAR.
Sulastic. Leaf Spring Shackle
https://www.powerstroke.org/forum/su...-shackles.html
Don't know if I posted this already but here:
https://www.ford-trucks.com/forums/1...-shackles.html
Old Oct 25, 2019 | 12:09 PM
Bently_Coop
@Overkill2 this guy installed some for the front
Looks like they have applications for both.
@seventyseven250 my bad on the misinformation
Old Oct 25, 2019 | 12:42 PM
Overkill2's Avatar
Overkill2
https://youtu.be/hmuixfRPSEY
No worries. He must have modified the Sulastic mount or modified the OEM front rear shackle mount to make it fit in the front. Unless it took very little modification. If you go to the Sulastic link I provided, you'll see it's for the rear axle application.
EDIT: I AM WRONG AND BENTLY IS CORRECT>>> FOR THE OLDER FRONT LEAF SPRUNG FORDS, THEY HAVE MOUNTS FOR THE FRONT SPRINGS.
