Sponsored by: Real Truck
6.4 needing help!!!
Old Oct 22, 2019 | 06:47 PM
William Dabney's Avatar
William Dabney
Exclamation 6.4 needing help!!!
So I'm having big problem with my 2008 ford f250, when I'm driving down the road about 25 mph the truck will start squeaking and the steering wheel will shake a little not bad though while I'm pushing the gas pedal in all the way up to 55 mph. As soon as I let off the gas pedal the squeaking will go away. Needing help I'm losing my mind over this, and maybe someone out there has had this problem and can help!! THANK YOU VERY MUCH
Old Oct 22, 2019 | 07:17 PM
droldsmorland's Avatar
droldsmorland
Squealing belt? Or a locked up accessory drive. (idler pully, steering pump, A/C compressor etc...).
Did you look at the serpentine belt?
Pull the belt and see if each item spins freely.
I'm not 100% familiar with the 6.4 if it has a belt-driven power steering pump.
BIGTRUCKBIGRV
Sep 10, 2017 08:36 AM
chaser1602
Sep 30, 2011 08:01 PM
JEB70
Jan 22, 2011 06:21 AM
chris86924
Apr 19, 2009 05:14 PM
