Vin info needed!! Thanks
Old Oct 21, 2019 | 09:32 PM
Sillvain12's Avatar
Sillvain12
So, slowly getting the info from mom on my dads 65 ford 350. And here is the VIN if someone give me more info on it.
F35DR699433
Just wondering if the manual trans was part of the original build or was it after.
Thanks
Old Oct 21, 2019 | 09:38 PM
RangerMercMan's Avatar
RangerMercMan
F35 is a 1 ton
D is a 352 2V
R is made in San Jose
the six numbers are the serial number which should also equate to 1965
The door tag should tell things like tranny, rearend, and interior
Old Oct 21, 2019 | 09:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Sillvain12
So, slowly getting the info from mom on my dads 65 Ford F350. And here is the VIN if someone give me more info on it.
F35DR699433
Just wondering if the manual trans was part of the original build or was it after?
TRANS & AXLE codes not within the VIN, stamped separately on the Warranty Plate.
F35 = F350.
D = 352 2V
R = San Jose CA Assembly Plant.
699433 = 1965.
Warranty Plate riveted to the left door face below the latch. Post a pic of it or type the codes.
Old Oct 21, 2019 | 09:41 PM
Sillvain12's Avatar
Sillvain12
Originally Posted by RangerMercMan
F35 is a 1 ton
D is a 352 2V
Ok, so the 460 and manual transmission that is in it isn't original then. I wish I knew when it was put in. My dad received it as a gift from a old guy for cleaning out a field and got it running back in the 90s.
Thanks for that info
Old Oct 21, 2019 | 09:43 PM
Sillvain12's Avatar
Sillvain12
F35 = F350.
D = 352 2V
699433 = 1965.
Once I get the truck out of the semi trailer this summer. I will get all the numbers off of it. And get pictures of it.
Old Oct 21, 2019 | 10:11 PM
NumberDummy
460 and manual trans swapped in, rear axle probably swapped too.
No 460 in F100/350 until 1973. No 460 with a manual transmission until 1983.
There are TWO different 460 engines, one is internal balance, the other is external balance.
The block casting number will determine which type it is. There may be an engine ID tag located on the coil bracket.
CelticOne
Oct 23, 2016 07:08 AM
vidaliaman
Jan 23, 2016 10:11 PM
MikeB 88
1983 - 2012 Ranger & B-Series
Jul 10, 2012 07:55 AM
junkydogg
Large Truck
Jul 24, 2011 02:39 PM
