Weel Well Vibration
Old Oct 9, 2003 | 09:56 AM
AusTex F-250's Avatar
AusTex F-250
Weel Well Vibration
I have a 2003 F-250 Lariat 6.0L PSD SD Fx4. When I turn (somewhat sharply), I notice a vibration that feels like it is coming from the weel well. It feels like the tire may be rubbing. Any thoughts?
Old Oct 9, 2003 | 12:56 PM
AusTex F-250
Wheel Well Vibration
Of course, I meant "wheel" not "weel" (in case you were curious, a "weel" is a wicker basket used to catch eels).
Old Oct 9, 2003 | 01:07 PM
dinebito's Avatar
dinebito
- do ya have the stock tires on it?
- are ya in 4wd by chance?
- did ya run over a cat perhaps?
Old Oct 9, 2003 | 01:10 PM
AusTex F-250
I have the stock tires - BF Goodwrench. The truck is not in 4 wheel drive. Maybe that is where the neighbor's cat went!
Old Oct 9, 2003 | 01:12 PM
dinebito's Avatar
dinebito
lets hope so~
Old Oct 9, 2003 | 03:50 PM
grinderman's Avatar
grinderman
Have you checked to make sure that the front hubs are not in the manual "lock" postion. They should be on "auto". This could create the sensation of a vibration. Does it make any noise? I tire rubbing would make a grinding type sound as it rubbed against the plastic wheel-well. Is it coming from one side or the other? You can check for tire rub against the truck by turning the wheels all the way in each direction while stopped and visually inspecting the tire clearance. Make sure nothing is hanging under the well (brakes lines, etc.) that could be interferring with the tire.
Old Oct 13, 2003 | 09:41 PM
cdtruckn's Avatar
cdtruckn
I know there is a issue with the front automatic locking hubs on this trucks not unlocking, My truck took forever to disengage after I went 4 wheelin, like 80 miles It felt like the ujoints were binding up in the front-end when i turned real sharp.
JCox85
2004 - 2008 F150
May 7, 2007 09:04 AM
pikiluvi
Nov 18, 2006 10:26 AM
Blue Tear
1978 - 1996 Big Bronco
Mar 13, 2006 09:30 PM
therude
Jul 8, 2004 10:55 PM
froman23
Offroad & 4x4
Mar 13, 2002 01:12 AM
