83' F-100 4.9L problem
Old Oct 9, 2003 | 09:41 AM
robio376's Avatar
robio376
I own a 83 F-100 4.9l straight six, how do i replace the head gasket, do I need the whole set or just the main seal?
Old Oct 9, 2003 | 10:42 AM
sail2244's Avatar
sail2244
Depneds on what you intend to replace. If its just the head you will need:
* Valve cover gasket
* Intake and exhaust manifold gasket
* Head gasket
This is about the minimum.
Old Oct 9, 2003 | 08:06 PM
allv8fords's Avatar
allv8fords
new head bolts are not a bad idea either
Old Oct 17, 2003 | 08:20 PM
kohlerjd110's Avatar
kohlerjd110
** ford did not recomend the use of an exhaust manifold gasket on the 4.9 the intake gasket however was used
