LED light bar
Old Oct 19, 2019 | 12:12 PM
cljimmy72's Avatar
cljimmy72
LED light bar
I have a 2008 f250 that I plow with. If I put an LED light bar on the back of my truck (running off the reverse light terminal in the trailer harness) am I going encounter any issues. I can't see very well backing up with the OEM reverse lights. Only going to use them when plowing my private drive. Thanks!
Old Oct 19, 2019 | 04:55 PM
Franklin2's Avatar
Franklin2
How much power will the LED need? If it's over a couple of amps I would run a wire off the battery to a circuit breaker, and then from the circuit breaker run the wire back to a bosch type foglamp relay. You may have room behind the taillight to mount the relay out of the weather. Run a small wire from the backup lights to the relay to trigger it on, and then your light bar will run off the power you added with the circuit breaker, saving any factory circuitry from too much load. If you use a relay you can add a pretty large light or lights back there. The bosch type relays commonly handle 30 amps.
Old Oct 20, 2019 | 04:18 AM
cljimmy72's Avatar
cljimmy72
Thanks Dave: I have not picked out the light bar yet. My grandson sells them and has dozens available. I will use your information in selecting the right one. I have been reading stories about guys trying to use LED lighting elsewhere on their trucks and having issues. Thanks again. Do I need a circuit breaker or will a fuse block work also?
Old Oct 20, 2019 | 05:43 AM
seville009's Avatar
seville009
For what it’s worth, I stuck LED bulbs in the reverse lights of both my 2006 and 2011 F350. There is a significant improvement in the light output (in my opinion), especially when plowing and it’s reflecting off snow. They’re not spotlights, of course, but they work very well.
I also use the backup lights that go into the trailer hitch and plug into the trailer plug so that they go on in reverse.
Both simple and easy modifications.
Old Oct 20, 2019 | 06:44 AM
cljimmy72's Avatar
cljimmy72
seville: What bulbs did you use in both cases? In the OEM reverse lights and additional ones you plugged into the trailer connection. Thanks
Old Oct 20, 2019 | 07:16 AM
seville009's Avatar
seville009
got them all on Amazon
The led reverse light bulbs are “Ibrightstar 9-30v Super Bright Low Power” - cost of about $16. Amazon has a vehicle check function to make sure it fits your vehicle
the trailer hitch lights are COR FAB GEN 2 Trailer Hitch Receiver Mount - cost of $175
Old Oct 20, 2019 | 07:59 AM
Franklin2's Avatar
Franklin2
If you did have a trailer hook-up back there that did have the reverse function hooked up, that would be a good place to put a large extra lamp back there for vision purposes. The trailer reverse is on a different circuit than the truck's reverse lights, and usually has it's own fuse in the fuse box also.
You could use a fuse or a circuit breaker if you added power directly to the battery. I am a fan of adding extra add-ons and wiring on top of the factory wiring, modifying the factory wiring the least amount that I can.
Old Oct 21, 2019 | 05:39 AM
cljimmy72's Avatar
cljimmy72
Seville: That is one nice looking hitch mounted light. I was thinking of mounting the light bar higher because I have backed into my bank a couple of times already (probably because I could see decently while plowing). I will consider this one though.
Franklin: I do have the reverse light available in my trailer connector. Thanks for your help.
Old Oct 21, 2019 | 06:07 PM
Franklin2's Avatar
Franklin2
I used to plow snow, several driveways and a parking lot. After awhile you get tired, and you end up backing up and letting truck truck drift back till it hits the snow you piled up, and then push forward as far as you can go, and the back into the snow bank again. My trailer connector led a rough life back there, and after a couple of years finally broke off.
Old Oct 22, 2019 | 10:49 AM
cljimmy72's Avatar
cljimmy72
I hear you! Mine is on borrowed time. Bent it back a couple of times! When it finally breaks I was thinking 3/16 or 1/4 angle iron!
jiggerk
Jul 19, 2019 06:21 PM
AMECG34
Oct 16, 2017 06:44 PM
vtfireftr
Apr 25, 2017 02:54 AM
Surge08
Delaware Chapter
Sep 11, 2008 10:29 PM
90ebbronc
1978 - 1996 Big Bronco
17
Feb 5, 2004 12:29 PM
