Someone stole my GN wheels/tires and cut brake wiring. 14ply upgrade?
I got lucky when I converted to 17.5's. I got 4 very slightly used Michelins for $200 and the rims new, with the right offset for $400. The problem I think you will run into with 19.5's are the rims. Finding the right offset, bolt pattern and reasonable price might be a challenge.
Exactly why the Sailuns have earned such a following, they are built as an all steel commercial truck steer position tire and branded as an ST to reduce the tariffs on them. They fit most RVs that came with 16" and some that had 15" factory rubber, like my TT, and offer far greater strength and durability than the cheap Load Range D or E tires common to that application.
Well then you haven't been running very good tires. The Goodyear G614 are 16" Load Range G tires with maximum inflation pressure of 110 psi. They are OE on many top-of-the-line trailers and last a heck of a lot longer than "a couple of years". I just changed my first set off of my Hitchhiker Fifth Wheel after 8 years of full-timing. Not because they were worn out or showing any signs of deterioration, but because I don't run trailer tires longer than that.
I just saw the Goodyear Endurance comes in a 255/85/16, which is a hair over 33" tall.
eddienelson
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
39
12-26-2019 05:54 PM
msgtord
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
03-28-2015 04:55 PM
JJFIVEOH
13
08-09-2005 12:04 AM
