Tool for ignition module
Old Oct 16, 2019 | 09:57 AM
Stinky_Sullivan's Avatar
Stinky_Sullivan
I pulled the ignition module off to have it tested. What kind of socket is used to remove the module from the heat sink? Any socket I have that is small enough to fit in the hole is too small to fit the screw.
Old Oct 16, 2019 | 10:45 AM
torq'ta 5 8's Avatar
torq'ta 5 8
adanced, autozone, oreillys, its called Ignition Module Wrench
Old Oct 16, 2019 | 10:48 AM
Stinky_Sullivan
My memory must be shot. I was a manager at Autozone 23 years ago and in knew EVERYTHING we sold on the floor but I don’t recall that.
Old Oct 16, 2019 | 10:49 AM
Scndsin's Avatar
Scndsin
This is what it looks like courtesy rla2005 :
Originally Posted by rla2005
I have one of these in my toolbox:
A thin walled deep 5.5mm socket works too.
Some say NAPA has them.
You can sacrifice a 5.5 mm socket (cause finding one thin enough is a pain) to grinder/electric drill/file.
This a post I did on what to do when you get them out:
Originally Posted by Scndsin
Thought I'd try & add to the knowledge base. No idea if it's covered here & I missed it.
The damnable screws that hold the ICM to it's heat sink are 5.5 MM heads.
I once had a nut driver with a skinny enough barrel to get them out easy.
The head being 5.5 MM translates to .216 inch & a 7/32 socket is .218 & some folk have told me they got them out with that.
I found that some spare after-market speaker screws that I had left over are 4 MM X 1.25 pitch and fit perfectly.
Double nut for the correct depth & never worry about not getting the ICM off it's sink again.
Old Oct 16, 2019 | 08:43 PM
TexasGuy001's Avatar
TexasGuy001
Thanks for sharing. I'll have to keep this in mind and watch for one.
Old Oct 16, 2019 | 08:46 PM
TexasGuy001
Last time I had to replace one of them, I ground down a 1/4 drive 7/32 socket to fit.
Old Oct 17, 2019 | 05:33 PM
EllieMae94's Avatar
EllieMae94
I found a 7/32 12 point deep well socket at Menards, "MasterForce", their house brand. Didn't need to grind it, worked as-is. Here's a link:
https://www.menards.com/main/tools/h...9286938&ipos=7
Old Oct 18, 2019 | 11:30 AM
woodson84's Avatar
woodson84
Old Oct 21, 2019 | 08:56 AM
Davidw45's Avatar
Davidw45
Deep 5.5mm Kobalt socket from Lowes fit perfect on mine. $3
https://www.lowes.com/pd/Kobalt-Metr...Socket/3387532
randre
Dec 29, 2023 11:57 PM
brentak
Oct 10, 2011 06:53 AM
aerovan
Aerostar
Jul 4, 2004 10:33 PM
BigRedBronc
1978 - 1996 Big Bronco
Jan 25, 2004 09:46 AM
dc76
Feb 1, 2002 10:28 PM
