Looking for
Old Oct 15, 2019 | 06:22 PM
74e200clasic's Avatar
74e200clasic
Looking for
Hello, I'm new here . Looking for parts for my 74 E200. Front wheel hub. Or information on what upgraded front end swaps everyone is doing these days?
Thank you
Old Oct 16, 2019 | 03:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 74e200clasic
Hello, I'm new here. Looking for parts for my 74 E200. Front wheel hub.
Ford did not supply just the hub, it was only available with the drum as a hub & drum assy.
C8TZ-1102-C .. Hub & Drum Assy / Obsolete
1969/74 E200.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
Old Oct 16, 2019 | 06:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
this will probably get better views in the 68-2013 full size van forums, so i am going to move it there
Old Oct 16, 2019 | 01:31 PM
baddad457's Avatar
baddad457
Thank you
Drum or disc ? Bolt pattern ? If it's 5 x 5.5, then something for an F series should fit
Old Oct 16, 2019 | 05:43 PM
NumberDummy
1969/74 E200 has 15" 5 lug wheels on a 5.50" bolt circle, 11" x 3" front brakes, same as 1968/72 F100 2WD
Beginning in 1975, all Econolines came with front disc brakes as standard equipment.
1961/1974 Econolines are unit bodies, 1975 was the first year for body on frame construction.
1971/74 Econolines have Power Assist P/S, use the Ford/Thompson "pencil neck" P/S pump.
1975 and later Econolines have Ford/Saginaw P/S, use the "canned ham" Saginaw P/S pump.
Old Oct 16, 2019 | 09:09 PM
baddad457's Avatar
baddad457
There, I fixt this
compaddict
Sep 12, 2012 10:23 AM
allfordtrucksjohn
Aug 30, 2007 09:33 AM
kjhinorbit
Sep 23, 2004 11:47 AM
