Friendly body panels
Old Oct 14, 2019 | 07:44 PM
needshave's Avatar
needshave
1996 F150,4.9L w/8ft bed
My old ford is going to need a new rocker panel on the drivers side. I will probably replace the rocker, Part of the floor extension and the bottom of the B post.
I ordered the new parts to make the repair from a local jobber. When I picked up these parts I found them to be so thin that you have to be careful picking them up. The floor section is so thin it will wave back at you. I refused the sheet metal repair panels. I might as well use paper mâché to repair it. Now i'm looking for a better quality part.
Has anyone made this repair and have a suggested source for parts that are at least close to the OEM thickness....and fit? I would appreciate any advise or suggestions. I intend to weld in place.\\
Thanks for your consideration..
Old Oct 14, 2019 | 09:03 PM
Edgethis's Avatar
Edgethis
I have used DynaCorn on other projects in the past. Not sure if they make panels for our trucks but on old Mustangs they are one of the better Repro companies.
Old Oct 14, 2019 | 09:24 PM
PlumCrazy7's Avatar
PlumCrazy7
I was pretty satisfied with the quality of the panels from RockAuto.
Old Oct 15, 2019 | 12:28 AM
needshave's Avatar
needshave
Edge,
Thanks for the info. I found DynaCorn on line, but nothing for the old F150, but they sure got a lot of Mustang stuff!
Thanks again..
Old Oct 16, 2019 | 10:59 AM
TobaccoBarn460's Avatar
TobaccoBarn460
I noticed in one of the companion threads below that accompany all threads, a poster recommended tabcoparts.com and it does sound pretty interesting, you want to may check them out.
Old Oct 17, 2019 | 12:38 AM
needshave's Avatar
needshave
Tobaco,
Thanks for the info. I sounds like they are selling a quality part. I have an email into them. I will post what I learn from them.
Thanks so much for the information.
mwoj
May 13, 2017 09:23 PM
jason867
May 23, 2008 01:09 PM
rusbukt
Apr 9, 2008 10:49 PM
lowboy250
Paint & Bodywork
Sep 25, 2007 10:36 AM
mulletmaster55
Paint & Bodywork
Mar 29, 2005 09:27 PM
