Vent window frame question?
Old Oct 13, 2019 | 11:36 AM
FuzzFace2's Avatar
FuzzFace2
Project just came to a screeching stop!
After fighting for a long time installing the new rubber and noted the new was not just like the old but moved on any way. Then found I installed it wrong and had to fix that.
Go to install the frame and cant get it to go in?
I even pulled the glass back out and still will not fit so I then try the other side I have not pulled apart yet and it will not fit also WTH?
I should point out that I had to get new frames as mine were rotten.
So I pulled out the old ones to match up and that is when it all turned to crap!
This is what I found.
I could not get them to fit because they were to long maybe 4" (did not measure) and was thinking I can cut off the extra and should fit but ...........
If you look the channel the glass would fit in it also wider.
Think they are from a newer truck? I got them years ago and don't remember from who now.
Now it looks like there is a spacer in there that takes up the extra space but they would then mean the glass is skinner.
So the question(s) is do you think I can use them by cutting the channel shorter to fit in the door?
What do I do about the spacer in the channel? I don't think the new channel seal will sit all the way in to
the bottom?
Anyone have good vent window frames they want to sell for a 81 truck?
Dave ----
Old Oct 13, 2019 | 01:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1980/91 F100/800 & Bronco // 1988/91 F(Super Duty):
EOTZ-1021608-A .. Right Vent Window Frame / Obsolete
HAVEN FORD PARTS in Haven KS has 1 = 620-465-2252.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
EOTZ-1021609-A .. Left Vent Window Frame / Obsolete
HAVEN FORD PARTS has 1.
NOS PARTS SOURCE has 1.
KAMA OBSOLETE PARTS has 1.
FORD PARTS ONLY in Bayamon Puerto Rico has 2 = 787-786-9180.
Old Oct 14, 2019 | 12:46 AM
FuzzFace2's Avatar
FuzzFace2
Thanks Bill
What I really need and called the wrong name is 22296 left& right
I thought 21408 left & right would have been part of it but guess not?
If they fit 80/91 I wonder what it is I have?
I will have to see if there are any numbers on them so I know.
Thanks again
Dave ----
Old Oct 14, 2019 | 02:02 AM
Kramercd's Avatar
Kramercd
Why did you pick up replacements? Old ones messed up?
Old Oct 14, 2019 | 03:11 AM
FuzzFace2's Avatar
FuzzFace2
yes big time.
Both the lower povits are broken, 1 nothing left as it rusted a way and the bottom of the channels are also rusted away just to start with.
I don't think it is worth the time to try and fix them if I can get some in better shape.
Dave ----
Old Oct 14, 2019 | 04:14 AM
NumberDummy
Thanks Bill. What I really need and called the wrong name is 22296 left & right.
If they fit 80/91 I wonder what it is I have? I will have to see if there are any numbers on them so I know.
No numbers...
E5TZ-1522296-A .. Right Division Bar / Obsolete ~ 10 available NOS
E5TZ-1522297-A .. Left Division Bar / Obsolete ~ 9 available NOS
Old Oct 14, 2019 | 11:33 AM
BRNWAXA's Avatar
BRNWAXA
I have a used set in Waxahachie Texas. Came from 80-86. I would guess thy need rubber but the parts are all usable
Old Oct 14, 2019 | 11:39 AM
BRNWAXA's Avatar
BRNWAXA
I may have additional vent window lever-locks also, and door latch bushings too. I would give that stuff to you. I can get it packaged and out quick.
Old Oct 14, 2019 | 11:46 AM
BRNWAXA's Avatar
BRNWAXA
Dave If you are interested i will send photos. I don't sit at a computer all day--- Call 972-935-6693
Old Oct 14, 2019 | 02:47 PM
FuzzFace2's Avatar
FuzzFace2
Pictures of the parts would be nice before shipping.
Shipping would be to Angier, NC 27501
I will PM you my full information.
Thanks
Dave G.
Old Oct 14, 2019 | 02:53 PM
BRNWAXA's Avatar
BRNWAXA
Can you send your Email in the PM
Old Oct 14, 2019 | 03:13 PM
FuzzFace2's Avatar
FuzzFace2
I sent you 2 PM's with the information.
If you need more please let me know
Dave G
Old Oct 21, 2019 | 04:08 PM
FuzzFace2's Avatar
FuzzFace2
I knew I would have an early get out day so took the wheels with me to work and on the way home dropped them off.
If all goes good I should have them by EBD but this is me (look below) LOL
Thanks to Bill aka BRNWAXA, member on FTE
With the parts I got from Bill and some of what I have will work to make a complete working set.
I see the parts have a bracket that looks to use a mirror screw to support the mirror & outer panel from cracking, I don't know if it will clear on my truck so I wanted to test fit.
Also wanted to test fit before I got into painting them & replacing the rubbers.
I tried to fit 1 in a door, after trying for 45 min. and only getting a little farther than I did with the other wrong parts I was going to try the other side when it hit me!
Why not see if the part is the same as what came out like I did with the wrong parts!
Well besides the bracket that I can cut off if I have to they are ALSO too long! Only 1.5 inches longer but enough I cant get it to pivot it into place.
When I have time, most likely this weekend, I will trim a little at a time till I can get them into place then I will make them look new before installing for good.
Dave ----
Old Oct 21, 2019 | 06:49 PM
yarddogg77's Avatar
yarddogg77
I pulled window seals from a 90's truck at the wrecking yard because my truck had a 60 mph whistle that was really loud. They were skinnier than my 86, so the skinny window channels you have would probably be from a newer model. Not sue what year I pulled from, seems like around a 93 or so.
Old Oct 22, 2019 | 04:20 AM
FuzzFace2's Avatar
FuzzFace2
yes big time.
Dave ----
It's the black window divider that is skinny not the seal.
Look at the pictures above as I have them next to each other to show this. About 1/2" skinner and 5 inches shorter that the first replacements. The 2nd set are 1.5 inches longer than what I pulled out.
I believe the doors & guts are all 81 parts, 11/80 is what the sticker has so could be left over 80 parts?
Dave ----
